Old 08-01-2004, 05:14 PM
fordforlife's Avatar
fordforlife fordforlife is offline
intake manifold
On my 351, the egr plate has been welded closed (it has a carb, the end facing the firewall) and most of the vacuum hoses have been plugged. All that remains are the essentials i guess, brake booster, vacuum advance, couple others that im not sure of. Would i be better off getting an aftermarket intake, do they make 'em that do away with all the extra vacuum stuff and egr plate? The engine is stock with 4 barrel carb.
Theres also a little flap thing that goes on the intake, dirver side, beside valve cover, it has a flap that sits in the intake and controls flow of something, well it has been removed also, just a plate covering hole up.
So basically my question is, since everything has been removed, do i need to bother with getting a different manifold. If so, what kind would you recommend. It would be a street application with a stock 351ho. Thx for all your help, sorry so long!!!!!!!!
Old 08-01-2004, 10:02 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Do you have to get a new intake manifold... no. Will a different one improve performance... yes!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-01-2004, 10:17 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: intake manifold
A Performer series intake from Edelbrock would probably be a nice choice.
Old 08-01-2004, 11:13 PM
Re: intake manifold
thx! is the performance worth the money??
Old 08-02-2004, 02:40 AM
Re: intake manifold
performance gain i should say.
Old 08-02-2004, 11:52 AM
351wStang's Avatar
Re: intake manifold
I've never personally used the Performer but from what I hear it is a nice investment for mild engines. It is intended for use from idle - 5500 rpms.
Old 08-02-2004, 07:57 PM
GTStang's Avatar
Stang Guy
I'd change the intake manifold and carb(if stock motocraft). It definetly makes a very nice difference in performance on a stock motor.
Old 08-02-2004, 11:49 PM
Re: intake manifold
would ebay be a good place to look, or do i need to get a brand new intake. (im getting a brand new carb) thx again!!!!
Old 08-03-2004, 07:35 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
You could easily find an intake, and more than likely there wouldn't be a problem, but sometimes you get screwed. So with that said, I would go new since they aren't extremely expensive.
Old 08-03-2004, 08:17 PM
GTStang's Avatar
Stang Guy
Re: Re: intake manifold
Thing with a used intake manifold is some could have cracked it just a lil bit from overtightening. It could have overheated and warped and now needs to be machined. These are all things you really can't tell from the naked eye. So it really is buyer beware on this one.
Old 08-03-2004, 09:10 PM
Re: intake manifold
thx man!! ive found some new ones for about 200, is that a reasonable price?
Old 08-05-2004, 11:36 AM
Rod&Custom's Avatar
Seems pretty reasonable to me!
Old 08-05-2004, 12:28 PM
351wStang's Avatar
Re: intake manifold
I would suggest Edelbrock's Performer intake, and a Edelbrock 500cfm Performer carb. You should expect to spend around $250 for a carb and about $150 for an intake. Good luck.
Old 08-05-2004, 05:03 PM
Rod&Custom's Avatar
???? What was I thinking? Stop listening to me. Listen to 351.... I was thinking that it was a late model, like in his avatar. Like he said, go edelbrock performer. Geeez....
Old 08-05-2004, 06:02 PM
Re: intake manifold
lol. thx!!! i found a 600cfm with vacuum secondary and manual choke for 200, and then an intake for 190. just gotta get the money now
