Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-31-2004, 11:06 AM
rimal rimal is offline
Clunking In Drivers Side Seat
Hi I purchased a 4 runner at the end of May 2004 after a couple of weeks i started getting a clunk on the drivers side. When i brought the vehicle in for service i was told that all the 4Runner SR5's did have the clunking noise. Was wondering if anybody else has experienced this problem Thanks By the way it is a 2004
Old 07-31-2004, 11:18 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Clunking In Drivers Side Seat
Search this forum. This has been discussed recently.
Old 08-06-2004, 01:39 AM
jj007 jj007 is offline
I also got a 2004 SR4 4-runner recently and noticed the same clunking. I was starting to think that there was something wrong with the driver's seat. Were you ever able to get an explanation as to what causes this or how it can be fixed? Thanks.
Old 08-10-2004, 04:29 PM
Re: Re: Clunking In Drivers Side Seat
I have an appointment tonite 8/10/2004 when i get an answer i will post it on the site Thanks
Old 08-11-2004, 06:25 PM
Brian R.'s Avatar
Resident Chemist
Like I said:
http://www.automotiveforums.com/vbul...d.php?t=213467
Old 08-17-2004, 10:14 PM
toyotamdt toyotamdt is offline
I see this problem at least once a week. when the 4runner was made they had a bad set of seats. if the noise that u are hearing in a click or cluck, slide the seat all the way up and squeeze the out track on the outer track assembly. this will just isolate the noise if it does go away the use a hammer and a punch and bend the track in so it will hold the inner slide tighter
Old 08-19-2004, 01:53 PM
kokopellidan kokopellidan is offline
I have a similar problem only I feel the thump whenever I make a sharp turn.
The driver's side seat has an adjustment in the front thaty lifts or lowers your legs at the knees.
It seems that the piece of metal or plastic that is under the front end of the seat that allows for this adjustmet has allot of play in it and tends to slide from side to side.
I also feel the thump iunder the seat whenever I accelerate.
My seat does not seem to be loose though so I chalk it up to just another annoying quirk due to poor Engineering that seems to plague this truck's design.
