Old 07-30-2004, 02:56 PM
d_man_83 d_man_83 is offline
Send a message via Yahoo to d_man_83
Mustang Oil
I have a 94 Mustang 3.8 and had a leak in the radiator. I took it off with no problems. I put the new on and since its automatic it has oil lines going through it. Well my problem is that the botom oil line is now leaking. Its tightened to the fullest and it still leaks...what should or can do to stop it from leaking?
Old 07-30-2004, 03:42 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Mustang Oil
Um.....This is the eclipse forum. See where it says Mitsubishi > Eclipse directly above your post.
You might want to try the mustang forum.
Thanks for stopping by!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-30-2004, 08:08 PM
george536's Avatar
george536 george536 is offline
Re: Mustang Oil
how do you confuse mitsubishi>eclipse with ford>mustang?
Old 07-31-2004, 04:12 AM
91_4ourbanger 91_4ourbanger is offline
Re: Mustang Oil
is there some kind of gasket, or O ring around the fitting, that isnt sealing?
and how DID you confuse the forums.
Old 07-31-2004, 01:45 PM
rerun rerun is offline
funny how everyone that who trys to look like they've never made a mistake before drives a 4 banger.. oh wait, i guess that's a ironic statment.
anyway, there could be some corrosion or somthing on the line, or it may need to be reflaired (if sealed by the flairing and not the threds or a gasket). also could be a bad line with a tiny hole some where that it not detectiable, could be a dent in the line where it seals too.. a LOT of things that it could be.
Old 07-31-2004, 01:51 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'd reflare it and make sure and hope you didn't cross-thread it.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
