Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 02-01-2002, 11:55 AM
kpw97 kpw97 is offline
Send a message via AIM to kpw97
Cruise control problems
Well, I posted this in the sr20 forum, but I'd like to get input from you guys as well. My cruise has worked fine, that is until I brought the car in to get a snapped exhaust manifold bolt replaced. He also changed the O2, so I reset the ECU afterwards. A few days later I go to use my cruise, the light comes on to say it's ready. Press the button to set the speed and NOTHING! It worked the week before that. So, I'm stumped. I tried resetting the ECU again to no avail. Any ideas?
Kevin
93 Classic Se-r
$tillen Pop and Header
Old 02-01-2002, 01:34 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Heck, I haven't even done any modification to my G20 and I have the same response! The "cruise on" light illuminates, but no response from the set button itself.
Try running a search in the G20 forum only on this subject. I do believe some other threads on this already exist, and some of your questions may have been answered!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 02-01-2002, 07:58 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Cruise really doesnt have anything to do with the ECU. If you open your hood, you can see where the throttle cable is attached to the intake. Right next to it is another cable, which is your cruise control cable that holds the throttle position open by use of a vacuum pump device by the drivers side winshield area.
What your first course of action is to check all the fuses for the ASCD (Automatic Speed Control Device) fancy word for cruise. Make sure they are all good.
-Brian Jones
I got a snake man
Old 02-03-2002, 11:17 PM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
Same problem here. I just assumed it was the ASCD Pump or the Actuator.... Didn't care to fix it, since i don't use cruise much
Maybe G20's tend to have cruise failures quite a bit? ....
-Phil
94 Ram no cruise controll mrkabokieman Ram Pickup | Ram SRT10 3 08-16-2009 03:36 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
Climate Control and Cruise Control Problem yakko Regal 12 10-03-2007 07:52 AM
'94 ABS / Cruise Control Problem as well as window problem cwru53 Cutlass Series 1 06-16-2005 09:35 PM
