Old 07-28-2004, 01:39 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Grinding reverse
My 88 mustang GT sometimes when shifting into reverse will make a grinding sound. The clutch is fully depressed and all other gears I have no problem with. Sometimes to limit the grinding ill rev the engine and it will slip into reverse with no grinding. Do you know what the grinding could be? This is the only gear that has this problem and its not consistent.
Thx for any input.
P.S. Its a quick grind.
Old 07-28-2004, 02:51 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
It's a fairly common thing caused by the tanny forks set-up. Try putting the tranny into first and then going into reverse. Either way it's not something to worry about.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-28-2004, 03:51 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Grinding reverse
Mine does the same thing. I go into 5th before reverse and it does not grind.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-28-2004, 10:18 PM
351wStang's Avatar
351wStang 351wStang is offline
Reverse isnt a syncronized gear. It may be spur cut if I'm not mistaken, been a long time since I built a manual tranny of any kind other than a Jerico. But yes if you go into a forward gear and then into reverse it should go right in just fine. Other than that if you can let the car roll just a little bit it will turn the tranny and should line the gears right up for you. But no it is nothing to worry about, just annoying. No fix for it that I know of.
Old 07-28-2004, 10:28 PM
andrewespo's Avatar
Thx for advice guys ill switch into a forward gear and then reverse. Also this is off the topic, but I was thinking about throwing in a cold air intake, it fits my budget,im wondering if i have to convert to mass air or i can stick with the speed density and still put one on.
Old 07-29-2004, 09:46 AM
kittedb18bt's Avatar
kittedb18bt kittedb18bt is offline
i guess we all have our own way of not grinding when going into reverse. i have the same problem on my 99 cobra. i put the car into second gear with the clutch fully depressed, and then put it into reverse. every way seems to work.
Co-Founder of AF V-Card Club
1999 Ford Mustang Cobra: Cobra R rims, Magnaflow CB.
"no way man...i saw an LS1 fight godzilla and the LS1 beat godzilla and it looked in the air and was like what do you think of that god and god was like bring it bitch so they fought and the LS1 beat god now the LS1 is god because its the greatest thing ever."
Old 07-29-2004, 10:17 AM
GTStang's Avatar
Stang Guy
Re: Re: Grinding reverse
You don't have to switch to MAF many companies make CAI for SD. Also if you are planning on switching to MAF someday BBK also makes a set-up that uses a spacer where the MAF would be so you don't have to buy a new CAI when you switch.
