Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 07-25-2004, 10:45 PM
unicyclemidget11 unicyclemidget11 is offline
1995 T/A questions
How involved would it be to repair the head from a blown spark plug? A guy cross threaded the spark plug and blew it out. How much would a new head cost?
What are some simple mods that don't cost a lot that I can put on the car itself to give it more hp?
Old 07-25-2004, 10:59 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Re: 1995 T/A questions
Headers and an Exhaust are a good (relatively) cheap mod for 350s.
Probably the most HP for your dollar would be a cam swap however. But that would be a little harder to do then just bolting on headers.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 07-26-2004, 02:28 AM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
A single LT-1 Head would cost you around $375-450.
I'm not sure if you're able to repair the damage of the crossthreaded bolt hole after it was blown out. But if you can, you can save yourself some money by using a Tap n' Die set to re thread the hole. That's only if the head is worth saving.
But to get the heads off of the motor, in a 4th Gen F-body as far as I know you'll have to pull the motor. And if you're going to go through that much trouble for a single head, you might as well throw on a set of after market heads for better performance. Might as well, you've already got the motor out and partially apart.
Like these Edelbrock heads: $529.99 a head.
Check out ThunderRacing for all your F-Body go fast parts:
http://www.thunderracing.com/
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 07-28-2004, 10:02 AM
landyacht's Avatar
landyacht landyacht is offline
Wow...Redneck again proves he knows his stuff!
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 07-28-2004, 10:09 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
I don't know about LT1's but I have pulled heads off of a LS1 4th gen without droping the engine. I was a pain in the ass but, it was better than dropping the engine.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-28-2004, 05:36 PM
-The Stig-'s Avatar
On Fire!
Re: Re: 1995 T/A questions
Well, both motors sit in the same position as far I know of in the engine bays. But yeah, it's a pain in the ass cause just about half of the motor is under the firewall.
To me, it'd seem easier to pull the motor and toss the heads on. While it was out, it'd be even easier to throw in a nice new roller cam.
Old 07-29-2004, 09:28 AM
Hypsi87's Avatar
Re: Re: Re: 1995 T/A questions
except that on a foruth gen F-body, you have to drop the frot sub frame and drop the engine from below, another one of GM's bright ideas
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 07-29-2004, 10:23 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
It's not necessary to drop the motor to swap the heads, but obviously preferrable if you have that option. Also, if you just want some replacement stockers, you can pick them up used for about $400-500 in good shape. People are constantly selling them over on camaroz28.com. For the price of new heads (~$1200), you can pick up a set of used heads that have had a nice port/polish job done to them already. Throw in another $450 for a cam kit and you're well on your way to a nice amount of power.
There's no replacement for displacement...No, not even a turbo.
Old 07-29-2004, 10:37 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I have help my friend do a head swap on his LT-1 without pulling the motor out but what a PITA!!!!!!!!
I'm sure you can fix your spark plug hole on the head. Even if you personally can't your local machine shop will do it for a decent price.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-29-2004, 05:14 PM
BullDog71ss's Avatar
BullDog71ss BullDog71ss is offline
Unless you plan on doing some real high performance modding to the motor spending bundles on aftermarket heads isn't worth it. Get some used stockers in good shape and have them ported, the stock heads will produce sufficient power. Then you can spend the money you saved on something else, like a cam and gears.
Old 07-29-2004, 08:17 PM
How wouldn't it be worth it???? Bigger valves, bigger ports, higher more efficient combustion chamber, stronger valve springs, and better flow. Now, I'd aggree with your statement if you were planning on doing what I said to the stocker heads, but not if all you plan is porting.
If money is tight, then he doesn't need to worry about modding his engine in the first place, so an after market set of heads would be out of the question. But if he has some a little money to spend, then why not get a higher flowing set of heads?
**1966 Chevy II**
