Old 07-25-2004, 07:35 PM
95gt4me 95gt4me is offline
Send a message via AIM to 95gt4me
Cool replacing rear brakes 4for my 95 gt
hi, e1 my name is randy,im new here so forgive me if i make any mistakes. i just bought a 95 gt conv. its super but it needs a rear brake job i already bought new rotors & pads is there anything speacil about ford abs brakes i should know? i haven"t done a brake job in years, (never w/ abs) . thanking you in advance for any advice. randy.
Old 07-25-2004, 08:07 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: replacing rear brakes 4for my 95 gt
When you go to pump up the brakes DO NOT push the pedal to the floor. Just barely push the pedal, very short and rapid. Otherwise you will be replacing a master cylinder too.
Old 07-25-2004, 08:13 PM
Re: Re: replacing rear brakes 4for my 95 gt
thank you but iwas wondering if there was more to it? someone menthioned somthing about turning the caliper?
Old 07-25-2004, 08:34 PM
351wStang's Avatar
Turning the caliper? Nothing about a caliper to turn lol. Just have to re-compress the piston in the caliper to slide it back over the rotor with the new brake pads. But it is good to turn your rotors even though they are bran new, they are probably still warped.
Turn rotors, compress calipers, lube pads with dielectric grease where they touch the calipers, pump brakes, test drive.
You should be fine, this is routine, good luck!
Old 07-26-2004, 08:30 AM
thanks again,(turning piston is what i thought i heard.)
Old 07-26-2004, 11:38 AM
351wStang's Avatar
Ya I think you may have to screw it back in. Should be able to get a tool to do it with at a parts store.
Old 07-26-2004, 12:34 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Most Rear ABS brake systems you need to turn the the piston back into the caliper cause of the emergency bvrake set-up unless it has a 2 brake set-up like a jeep or others. The tool is available at ya local parts store for like $10.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-27-2004, 03:41 PM
thank you all, you were right the piston has to be screwed back in, i did it was simple, i look forward to doing some mods in the future,with your help. thanking you in advance randy
Old 07-27-2004, 07:23 PM
GTStang's Avatar
Stang Guy
Glad to hear it worked out for you and definetly come back to talk about mods. That is what we really like to talk about round here!
