Old 07-23-2004, 06:52 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Favorite glue?
I know there's already a thread on glue, but I just wanted to know what glue everyone uses...brand and what it's called.
I use Testor's glue in the blue tube. This stuff is terrible. Everything I glue falls off with a slight tap but it sure ignites like no other
Old 07-23-2004, 07:03 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
Re: Favorite glue?
Tenax-7r is the best in my opinion
http://www.tenax7r.com/products.htm
Old 07-23-2004, 07:07 PM
bvia's Avatar
bvia bvia is offline
Re: Favorite glue?
Testor's liquid glue in the black kite-shaped bottle with the red label.
Bill
Old 07-23-2004, 07:42 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
Re: Re: Favorite glue?
Bill
Same here.
Old 07-23-2004, 07:53 PM
Paul the Greek Paul the Greek is offline
Re: Favorite glue?
I mostly use epoxy. CA glue and I just don't see eye to eye.
When gluing two pieces of styrene together seamlessly, I use Faller Expert styrene cement.
~~ Paul
Old 07-23-2004, 07:54 PM
Vric's Avatar
Vric Vric is offline
Bill
I use that too, or Humbrol clear glue
Anyway I always put some glue on a paper then use a small peice to put the paint on the kit.
Old 07-23-2004, 08:01 PM
SnakekanS SnakekanS is offline
Re: Favorite glue?
Humbrol precision poly cement !! (blue bottle with yellow cap)
the precision of glue you can put is simply amazing
Old 07-23-2004, 09:32 PM
Okiemodelbuilder Okiemodelbuilder is offline
I use several different glues depending on the application. I use Testors Liquid Cement in the black plastic bottle, Ambroid Pro Weld, and my favorite is Devcon 5 minute epoxy. I use CA for some things but it is not my favorite.
Marc
Completed Pro Touring Projects
...the pro touring experts
Old 07-23-2004, 09:41 PM
supratuner's Avatar
i usually use the Testors glue in the orange tube
or super glue if its for some thing that no body will see
Old 07-23-2004, 10:00 PM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
99% of the time super glue. It's sandable, strong and if applied correctly invisible.
The other 1% of the time testors liquid brush on glue.
Future for photo-etch emblems.
Old 07-24-2004, 02:56 AM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
I use the revell glue with a metal nozzle because its all i can get and its cheap too. For clear parts i use humbrol clearfix.
Old 07-24-2004, 08:27 AM
lotus_man's Avatar
lotus_man lotus_man is offline
Re: Favorite glue?
For styrene I use Slaters MekPak. Fast flashing and brutal on platic.
CA wize I use various grades of Xa depending on the job, usually the thick stuff but I also have very thin and non-fogging.
Epoxy wise I have devcon 5 minute, and 6 and 24 hour Arldite.
For glazing I stick with some brand-x 'Cockpit' glue I found in a radio controlled plane shop. It's like very stron white glue that thins with water but dries totally clear. It kinda like a huge bottle of Krytal Klear but way cheaper. I also keep a tub of contact adhesive to hand for BBR's etched metal/flat acetate windows.
Then there's always gloss varnish which I use some time for finishinh peices on bodies.
It's horses for courses really, I don't find that there is one wonder glue that does it all.
My current work-
Old 07-24-2004, 09:03 AM
Re: Favorite glue?
that glue in the orange tube is the worse thing you can use lol.
Old 07-24-2004, 11:24 AM
supratuner's Avatar
ok what ever u say
the blue tube takes way too look drying time
the orange still takes a while but is quicker, and ive been using it for aobut 2 years, not only for model cars, but model trains, and some little pieces of art work that i do, never had a problem with it
Old 07-24-2004, 11:37 AM
Vric's Avatar
Re: Favorite glue?
Glue in tube (like Testor) IS the first way to scrap a model. I stop used it at 13 years old
