Old 07-19-2004, 06:54 PM
LiquidSmooth LiquidSmooth is offline
Send a message via AIM to LiquidSmooth
quick question plz! help, so i can buy quick
so you can hook a 2 channel up to two subwoofers right? or do i need a mulit or mono amp for that?
Old 07-19-2004, 07:13 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: quick question plz! help, so i can buy quick
yes
Old 07-19-2004, 07:14 PM
i hooked 3 speakers up to my 2 channel amp.. i just bridged them
Old 07-20-2004, 12:06 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
you rebel...
Old 07-20-2004, 12:14 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
There is a lot of ways and configurations you can hook-up subs and amps. There are reasons for each,I think you should do a bit more reading.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-21-2004, 02:28 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Go to Circuit City (where I work) and talk to the car audio guys. They'll tell you the best setup for your money. Buy quality and not necessarily the highest wattage. anything other than a 4ch would be fine. get it hookedup by someone who knows what they are doing if you need to bridge or your using 2-ohms instead of four.
I have:Apline 350 4ch., Apline 500 (2-ohm) monoblock, Infinity Kappa 4x6s & 6x9s & 10.1D Sub, 1-Farad capacitor
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-21-2004, 02:40 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
quick question here....
since u work at circuit city. lol i have 2 10" rockford HE subs and right now i have a 2channel 500w rockford amp. I want to upgrade my amp. any suggestions? i kinda wanna stay with rockford for my truck cause everything else is.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 07-21-2004, 11:46 AM
Re:
I actually sell everything at Circuit city except for car audio. So I'n not up on what particular R.F. models are out. But it depends on the power handling of your amp and your subs. You may not need to upgrade your amp, maybe the subs instead. If your amp is not getting the RMS power to the subs that they are capable of then yes upgrade the amp. Amount of power that you are getting from the amp depends on how you have it hooked up. Your probably not getting 500w from the amp. the advertised numbers always show the max. capable, but not what you get in a typical setup. Look at the specs/manual for the amp. It should tell you how much power it is putting out for 2channels @ 4-Ohms. if this is lower than what you subs are capable of, and you have them wired straight (not bridged), then upgrade amp. Don't just look at the max wattage numbers, look at the RMS numbers too. Match RMS on amp to RMS handling on subs. Some of the cheaper amps, don't even show RMS numbers.
Old 07-21-2004, 02:29 PM
what's the difference between 2 ohm, 4 ohm, and 8?
Old 07-21-2004, 03:35 PM
korndogg's Avatar
i kno all about wattages and stuff. i was just wondering what newer amp you could recommend. just wanted some suggestions thats all. my system is one of the loudest around here in a truck actually.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-21-2004, 04:35 PM
i have a power acoustic 1600 watt amp... i like it
Old 07-21-2004, 04:39 PM
korndogg's Avatar
good for u ridge.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-21-2004, 04:42 PM
Re: Re: quick question plz! help, so i can buy quick
Originally Posted by korndogg
good for u ridge.
..... is that spose to be a smart remark?
Karen512's Avatar
Karen512 Karen512 is offline
Send a message via AIM to Karen512 Send a message via Yahoo to Karen512
you haven't heard mine tho.......
2004 SRT-4
1998 GMC 2500
1996 Eagle Talon TSi AWD Turbo
1993 Eagle Talon TSi AWD Turbo
1985 Nissan 300ZX Turbo
1990 Nissan 300ZX Twin Turbo
Past Z Cars Crew
Old 07-21-2004, 04:48 PM
korndogg's Avatar
Re: Re: Re: quick question plz! help, so i can buy quick
suppose to be. did i achieve it?
1968 Camaro 327
{o,o}
|)__)
O RLY?
