Old 07-18-2004, 03:51 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Help Please!
There are three major remaining problems I have yet to fix to get the "show on the road."
1.) My battery light is still on. I just installed a brand new battery yesterday and the alternator is like 2.5 years old. 2 of which the car was out of commission. I dont know what else to check?
2.) It's still running rich, really rich. In fact even if I open the garage door it still burns the eyes and nose. Fuel pressure is bottomed out at 37 psi; if I unscrew it any more the fitting is gonna pop out! Any thoughts?
3.) The transmission is still not shifting right. It shifts way too early. If I'm in D or OD and I floor it, it doesn't even shift at all! The only way I can drive it is to use the manual pattern. I adjusted the TV linkage to spec(33 psi) using a pressure gauge and the linkage block. Again, any thoughts?
P.S. I tryed pulling codes but the setup that was posted by HiFlow didn't work on my car. Are there ANY other ways to pull codes?
Thanks all
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-18-2004, 10:00 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I might be able to help you with one. Is your AOD stock? or do you have a shift-kit?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-18-2004, 10:24 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Help Please!
Try this for TV adjustment.
http://www.tccoa.com/articles/tranny...st/index.shtml
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-18-2004, 11:55 PM
Thanks HiFlow, that actually worked pretty well compared to what it was doing before. Unfortunately, I've got some really bad news. I got home after that test drive and heard a hissing sound coming from my engine somewhere. Sure enough, there was coolant coming out of the head studs!!! I just recently heard, over at MustangWorks, that the Sportsman block uses a longer stud in the lower holes. Something about affecting the water jackets. Anyone heard of this? I really dont wanna have to put on new head gaskets already. Especially at $120 a pair! Do you think, if i cant find em, theres anyway to safely sneek in new lower studs without pulling the heads?
Old 07-19-2004, 01:05 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
you didn't put sealant on the bottom row of head studs when you installed them did you? mistaaaaaaaake. those all need a bunch of silicone to keep your head gaskets in one piece...
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
