Old 07-12-2004, 04:26 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
pulling codes
I tried searching, but to no avail. What do you do to pull codes again? On a 92 GT.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-12-2004, 06:03 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: pulling codes
Locate the self test connectors on the drivers side inner fender well. You can find these, by finding the one which looks similar to the shape of a house. Hook up with a jumper wire as shown in the diagram below. Turn your key forward onto accessory (KOEO, key on, engine off), and wait for the codes. Codes will start with an 11 (meaning ok/done or ready) followed by any thrown codes, then will end with an 11. (note, that if no codes are thrown, and 11 will appear just once). Fix any codes from the KOEO test before you do the running test (KOER, key on, engine running). Finally when finished reset your cars computer, do this by disconnecting the negative side of the battery while leaving your headlights on for 20 minutes.
[IMG][/IMG]
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-12-2004, 11:23 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Look at that he has a picture and everything!!!! Now we know why he is the Mustang Mod!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-13-2004, 12:29 AM
Thanks HiFlow. Where am I looking for the codes, I've never pulled codes on a non OBD-II car?
Old 07-13-2004, 09:19 AM
HiFlow5 0's Avatar
Stanger
Re: pulling codes
Check engine light on the dash, or you can use the multi-meter and count sweeps of the needle.
-2013 Ford Flex
-1999 Ford F150
Old 07-13-2004, 11:33 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Re: pulling codes
What if its digital?
Old 07-13-2004, 12:10 PM
Re: Re: Re: pulling codes
Yeah, I've got a Fluke 87 - Digital
Old 07-13-2004, 01:03 PM
burly94gt burly94gt is offline
Re: pulling codes
lets all say it together..."hiflow is a badass!"
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 07-15-2004, 08:04 PM
Well it didnt work. I hooked it up perfectly to the drawing. I tried it like 5 times with and 5 times without the VOM re-adjusting the wires every time to no avail. When I hooked up the last wire in the drawing I could hear the fuel pump prime as well as a couple relays clicking on and off. Then the CEL came on, but did not flash when I turned the key to either ON or ACC.
Old 07-15-2004, 08:37 PM
HiFlow5 0's Avatar
Stanger
Re: pulling codes
Maybe your check like is burnt out?
-2013 Ford Flex
-1999 Ford F150
Old 07-15-2004, 09:20 PM
But wouldnt it not come on then?
Old 07-16-2004, 01:53 AM
HiFlow5 0's Avatar
Stanger
Re: pulling codes
I'm sorry, I didn't see the part in your post where you said the light came on. Did you try starting the car and running the test. Could be there's no stored codes for KOEO. Try KOER now, and see what happens.
-2013 Ford Flex
-1999 Ford F150
Old 08-02-2004, 11:57 AM
icetigr icetigr is offline
Re: pulling codes
Would the same sequence hold true if I wanted to reset the ECM on a 97 Cobra?
