Old 07-10-2004, 07:34 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
rocker question
will 1.6 rockers work on a mid 70's 350 block(stock pistons) with 89 305 heads? the guy that owns this engine says they'll work, but i have my doubts. i think the pushrod slots would probly have to be enlarged but i dont know. any thoughts?
Old 07-10-2004, 07:58 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: rocker question
i think they will work. look at the pushrod slot. if its actualy a slot then it should work. if it is ALOT more like a circle then it will need to be enlarged. i dont know how the heads were in 89, it might it might not. if your still unsure, then just buy the pushrod slotting tool and make them bigger. they dont cost that mich i dont think and its not that complicated.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 07-10-2004, 09:57 PM
Deadcarny Deadcarny is offline
Re: rocker question
they will work, the only thing to think about is Coil bind on the springs and Piston to valve clearance.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 07-10-2004, 10:12 PM
Re: rocker question
yeah you will probably need new springs for sure. as far as hitting the pistons, if the piston has valve reliefes then your cool, if not i dont know if i would even concider it. but it also depends the total amout of valve lift that it will have.
<<my engine
Old 07-11-2004, 02:55 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Bottom line is anytime you do something like this unless someone has done the exact same set-up with everything the same. You need to assembly it and spec it out especially the piston to valve clearance. You can make educated guesses and math it out a bit but it ends up you have to take the time and tolerance everything to know you were right.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-11-2004, 04:59 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: rocker question
If you have a mild cam then you won't have any problem at all with springs or valve to piston clearance, if you have a hotter cam then you need to make sure that your springs are rated as such. When you buy springs they'll give you the gross valve lift specs. Then take the lobe lift on your cam and multiply by 1.6. If you have a built engine then I'm sure you have valve reliefs and that won't be a problem. If not then I would invest in some new pistons. But that's just me.
Old 07-11-2004, 08:31 PM
Re: rocker question
Stock cams with 1.6 Rockers are usually VERY close to coil bind, and in some cars are beyond coil bind. Most stock Performance GM springs coil bind near 0.500".
1965 Ford F100
1992 Astro EXT AWD
www.SCFYB.com
