Old 07-06-2004, 01:27 PM
ccardoso ccardoso is offline
01 Caravan Rear wiper and washer pump problem
I have a 2001 Caravan. The rear wiper and washer pump stopped working at the same time. I checked the harness and connector attached to the wiper motor and it has power. Anyone know what the problem may be?
Old 07-07-2004, 08:38 AM
yogi_123rd yogi_123rd is offline
Re: 01 Caravan Rear wiper and washer pump problem
If there's power going to the motor, then this sounds like you have a poor ground. The motor is usually grounded thru its mounting bolts. To test if this is the problem, use a lenght of wire as a jumper wire. Turn on the wiper switch and touch the outer casing of the motor to a GOOD ground on the frame. If the wipers work, merely secure the wire as a ground strap in some way to the motor.
Old 07-12-2004, 10:00 PM
Thanks, I'll try it.
Old 11-18-2006, 10:00 PM
jimmymarcie jimmymarcie is offline
Hi did you find the problem, with your wiper & washer on your 01 van. Please let me know Thanks Jim
Old 11-19-2006, 11:12 AM
vipergg vipergg is offline
Go under the hood and pull the IOD fuse for a couple minutes and then reinsert, this resets the bcm and has fixed this problem in the past.
Old 12-15-2007, 01:40 PM
JesseA JesseA is offline
Thank You!! I have a 2001 Town & Country minivan that the rear wiper and washer stopped working at the same time. I pulled the IOD 15A Fuse for a few minutes, popped it back in and Viola! Saved me a visit to the dealer.
Old 12-16-2007, 10:01 PM
HeadlessHorseman1 HeadlessHorseman1 is offline
I wonder if that trick will work on a '96 GC/LE with a different problem. My rear window washer decided to pump all the fluid out of the tank and keep on running. I had to disconnect it to get it to stop.
