Old 07-06-2004, 01:27 AM
cheap5.0 cheap5.0 is offline
Rusted floor, can it be fixed?
I removed the driver seat tonight to fix an annoying wobble when i discovered the wobble was caused by rust. The front left bracket and the rear left brackets were bolted to a completly rusted section of the floor, i can see all the way through to the ground. The size of the hole is about 1.5ft square. Can i weld in some sheet metal and then brace it somehow? I was thinking i could weld somethin in, the drill new holes for the brackets to bolt onto. Sound good?
1993 Grand-Am GT...SOLD!
1982 VW Rabbit.......SOLD!
1988 Cavalier..........SOLD!
1989 Mustang GT 5spSOLD!
2002 Celica GT-S 6spSOLD!
2005 Jeep GC, 5.7 HEMI, heated leather and Alpine goodys
Old 07-06-2004, 01:40 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
You can buy new floor sections they are not that much. OR you could just cut your own sheetmetal piece and weld it in. Either way I would suggest welding in some sub-frame connectors when you done. They run right under the seats and help stiffen up that whole floor pan.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-06-2004, 04:42 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Rusted floor, can it be fixed?
Yeah you can weld in a patch, me and my brother did it on his '78 bronco. make SURE you cut out ALL of the rust and half rusted parts, you have to weld to a solid piece of metal!!! Welding it to a half rusted part will just leave you with a weak patch that will probably break off. After you are done, paint any surface rust anywhere else on the floor with POR-15 rust paint. Its meant to be applied directly to rust. Its expensive for a reason, it WORKS. This aint no Rustoleum spray paint.
http://www.por15.com/product.asp?productid=6
$100 bucks a gallon. You probably wont need more than a pint or a quart depending on how much of the floor you paint. I painted an entire '78 bronco frame with 3 pints.
Old 07-06-2004, 06:06 PM
where can i buy new floor sections from, and if i went the other route where would could i find the sheet metal? I.E....what type pf buisness, or specialty shop?
Old 07-06-2004, 06:13 PM
duplox's Avatar
You can get sheet metal at your local lowes/home depot, for a price. You'll probably pay around $10-$20 for a 2'x2' piece. I get all my metal from my local metal recycler. They have a warehouse filled with recycled metal. Its quite a bit cheaper there, but it still ain't cheap. Steel has gotten very expensive...
Old 07-06-2004, 06:16 PM
duplox's Avatar
by the way, here is a replacement floor section:
http://www.mustangsunlimited.com/ite...=&catkey=74-01
I doubt you need all of it, maybe some places have just a front/drivers side piece. Mustangs unlimited also has a passenger side version of that.
Old 07-07-2004, 05:03 AM
A friend of mine that i work with says he can get me sheet metal for free from his neighbor. I can not weld, but i do have a pop rivet gun! SO i think i can just rivet the sheet metal to the bottom after i cut all of the rotted metal off from the car. does this sound about right?
Old 07-07-2004, 11:23 AM
duplox's Avatar
Hmmm... You need to make it seal otherwise you'll have water splashing in.. and therefore more rust and a wet car. I suppose you can rivet it and get some epoxy(I use POR epoxy) and fill all the holes.
Old 07-07-2004, 02:52 PM
Thanks for the advice.
Old 07-07-2004, 06:02 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i can weld... if you live somewhere in SE MI i'll help if i can
riveting is a real halfass way to do it imho....
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
