Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 07-01-2004, 06:48 PM
nose-gobblin's Avatar
nose-gobblin nose-gobblin is offline
Send a message via AIM to nose-gobblin
All Focus 5-speed DRIVERS POST HERE!!!!
I have a test/ question for you guys:
I want you to go outside get into your car and start driving go exactly 35 mph and be in 4th gear, ok? simple enough right?
Then i want you to GIVE IT SOME like you where trying to pass a guy with out downshifting and tell me what you hear, i hear a chattering noise and the car dealership who had it in shop for 11 days said that it was indicative of the focus, that it is supposed to do that? pelase tell me the
YEAR:
MILEAGE:
and if it does it THANK YOU PLEASE HELP!
Old 07-02-2004, 07:11 AM
freakray freakray is offline
AF Modelrater
Re: All Focus 5-speed DRIVERS POST HERE!!!!
Yep, mine did that, I believe it's because there is no power available in that gear for acceleration.
AF User Guidelines
Old 07-02-2004, 05:31 PM
OK d00D +h4T5 pHOr the H3lP h0p3FuLlY m0R3 WILL pO$t H3Re $0On
Old 07-07-2004, 09:37 AM
landyacht's Avatar
landyacht landyacht is offline
Nosegoblin, don't post if you can't write English. Go to the non-English forums if you're gonna post like that.
Now to the point of this thread. The Focus doesn't have the proper power band in that gear at that low speed to be responsive, so that sound you're hearing is your transmission struggling to get you going.
My suggestion is that if you're at 35mph, don't use 4th gear. 35mph is roughly 50km/h, in which you can use 5th to keep fuel efficiency optimized and cruise easily. Should you need to speed up/pass, 5th will do fine.
Really, if you need to give'er at 35mph, you should be dropping it to 2nd to bring the revs right up high and get the engine working, then slamming it into 3rd to get the best performance. That's just my though.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 09-11-2004, 12:16 AM
stkitsfocus stkitsfocus is offline
Smile
hi there
I think that this is b/c you are going to slow. you should be in 3rd. I'm in 4th between 60km and 80km....maybe that's the chattering? Or maybe it's about to bite it
I think my focus could be about to bite it....all i need is a match and some gas-o-line
Old 09-14-2004, 01:03 AM
ZX2000 ZX2000 is offline
ive got a question... what are the gear ratio's for you focus tranny? cuz even if they're really high... you still shouldn't use 4th at 35 mph... common sense says so... i can use 4th in my zx2 that low but not for acceleration purposes... just for shit like cruisin to save gas. but if your tryin to step on it... downshift... ive found that 2nd works wonders in a situation like that...
Old 01-25-2005, 07:00 PM
lineman_07 lineman_07 is offline
Talking Shifting Problems
I have a 2001 Focus SE Manual and I find that it's a High-End shifter, I have done 80 Km in second and it hasn't red-lined. To answer your question, it sounds like to me your definetly in the wrong gear, a manual car will shutter if you are in too high of a gear for the speed and RPM's.
Old 01-26-2005, 08:47 PM
focusyn focusyn is offline
The Focus does not have the power to pull from 4th at 35 mph. Well, it won't pull up a hill and it certainly won't pull strong enough to pass anyone safely. If you were on flat ground, you could get it to pull in 4th, but you'd be waiting a long time. Better just to downshift to 3rd.
If you want a little bit of power, make sure the tach is above 2000 rpm, above 2500 is better. The engine is pretty wound up at that point. If you want RIGHT NOW power, make sure it's above 3000 rpm. Remember, this is only a 2.0 liter 4 cylinder engine. there is very little power below 2000 rpm in all gears.
I use 5th quite a bit and I can get pretty close to the EPA rated mileage in the city, if I don't beat on it AND WITHOUT obeying the shift light And I live in Pittsburgh, PA not a flat area to drive in.
Old 02-02-2005, 08:36 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
wow, i never knew they had mini-vans with manual transmissions, guess ya learn something new everyday.
Old 02-02-2005, 09:09 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: Re: All Focus 5-speed DRIVERS POST HERE!!!!
Who mentioned minivans???
-Chuck
Old 02-03-2005, 12:27 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Re: Re: All Focus 5-speed DRIVERS POST HERE!!!!
i think you missed the sarcasm of the meaning of the word "mini-van.".
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-14-2005, 04:01 PM
J-Ri's Avatar
J-Ri J-Ri is offline
4th gear at 35, huh? I had a friend with a Mustang 5.0L that couldn't accelerate from that slow either. Dunno if it's ford, or their drivers.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-14-2005, 05:04 PM
JTex JTex is offline
Simple, it's only a 4 cylinder engine. Take a crotch rocket at 35mph in 4th gear shifting to 5th it'll probaly die on you. You could gear the car differently but what do you want from a car designed for economy w/sporty looks or sacrifice the gas mileage and all the engineering that went into the car to make it handle well just to look like a ricer!
JT
Old 02-15-2005, 06:25 AM
wouldn't RIGHT NOW power be at like... eh, 4500 rpms?
You don't have to lie to make friends... keep that in mind next time you post.
Old 02-15-2005, 10:39 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
35mph? down that bitch to 2nd lol
