Old 06-24-2004, 06:53 PM
RocketStang911 RocketStang911 is offline
My friend and I went to the track.He ran some slow times.What is wrong with his car?
My friend and I went to the Drag strip last night in his 95 mustang gt.This was his first time taking his mustang to the track and he wanted to see what it would run.Well turns out he was only running low 10's in the 1/8 at around 70-74 mph.It is an auto but is has 4:10's,full exhaust,pulleys and an air intake.He ran with no tire and jack too.
He ran mostly against ricers that were running high 10's.Now doesn't his time seem a little slow for his car and his mods? But I think I know what the problem is.After racing in the car with him at around 60 mph (don't remember if it was 2nd or 3rd gear) his car was at 5000 rpm's and it stayed there and wouldn't shift for about 3 seconds giving the other car plenty of time to catch up then it finally shifted.When he raced he took the ricers off the line then started pulling on them and when his car went to 5000 rpm's and wouldn't shift for 3 seconds the hondas would actually catch up right next to him then his car would shift and he started pulling real hard on them.We talked to the guy we raced and he had an early 90's honda with only a CAI and exhaust.He ran a 10.8 as to my friend ran a 10.2 Do you think there is something wrong with his shift points because of the 4:10's?We talked to some mustang guys there and they said with his mods he should be running low to mid 9's in the 1/8.They also said his car needs a shift kit and that will solve the problrm.Is that what it is? Does his car need a shift kit.
Oh yeah he also ran his car with o/d off.That was even worse he told me 1/2 way down the track his car hit 5000 rpm's and it stayed there and didn't shift at all so his car kind of glided the rest of the way down the track just sitting there revving at 5000 rpm's.
Old 06-24-2004, 06:57 PM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
Re: My friend and I went to the track.He ran some slow times.What is wrong with his car?
His tranny is F'ed up.
A shift kit changes how the computer controlls the shifting. IE: how fast it shifts, at what rpm.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
Old 06-24-2004, 07:06 PM
He said his car drives and shift fine under normal driving and accleration.Could this be from his 4:10's because before the gear change he never had a problem.
Old 06-24-2004, 10:13 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Sounds like he needs a shift kit. It is probably computer controlled which softens the shift to much.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 06-24-2004, 10:23 PM
eillob's Avatar
eillob eillob is offline
All I can tell you is that the computer in these 94-95 mustang GTs SUCK. I've got a stick and can tell, I can't imagine what its like in an automatic. More than likely its computer related, the computer not only controlling the shift points its also pulling timming while its shifting and accelerating. Im performing an A9L swap this weekend if my kit gets here tommorrow. I'll let you know how it goes.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 06-24-2004, 11:53 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I think he just needs a shift kit, chip(that changes his shift points), or the Baumantor TCS.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-25-2004, 12:10 AM
Will a shift kit alone stop this shifting problem?
How much is a Baumantor TCS?
Old 06-25-2004, 12:58 AM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Shift kit is definately the way to go. He needs to make his shift firmer and snapier and a shift kit will do that.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 06-25-2004, 01:07 AM
GTStang's Avatar
Stang Guy
Re: Re: My friend and I went to the track.He ran some slow times.What is wrong with his car?
Well the stock AODE in your friend's 95 is set-up as a compromise of performance and daily driving. So even in stock trim at WOT there was some hesitation before shifting the 4.10's have just made what was always there and amplified it. If you got in my car as it is with the Trans-go shift kit the 1-2 shift when not under full throttle is snappy enough to whip your head back not exactly something mom or grandpa wants to deal with every day. Under WOT shifts fast with no hesitation and feels perfect. Maybe that explains why a shift-kit or chip or baumantor TCS can all fix the problem.
I think the baumantor TCS is like $400 but I really don't remember...
