Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-24-2004, 11:55 AM
Biker Biker is offline
Send a message via AIM to Biker
Question No Brake lights
I have a '94 Explorer XLT and BOTH brake lights are out. I have both taillights, L/R turn signals, 4-way flashers working. I checked the bulbs which looked good, but replaced both of them anyway since the bulb was a little blackish and they still don't work. I do not have the fuse diagram, so I just started taking out 10 and 15 amp fuses to look at and all appeared ok. I did find a previous thread that someone gave the fuse list with numbers and locations. Location #1 is a 15amp fuse for stop lamps, hazard, speed control. I guess this would not apply then since I have the hazards working. The other day my girlfriend took the car through the car wash and said the ABS light came on and she heard a 'strange noise'. The ABS light stayed on a few minutes then went out and has not been on since. I am really, REALLY at a loss here at this point. Does anyone have ANY ideas for me to try? If I have to take this into the shop to have the wiring checked, you know they will rape me big time with a $$$$$$ bill.
Thanks for your anticipated help.......
Old 06-24-2004, 12:31 PM
BigBadWimp BigBadWimp is offline
Re: No Brake lights
I had the same problem with my '94 Explorer Sport: Taillights worked and turn signal worked but no brake lights. I checked the bulbs and amps just like you and then I discovered what it was. On your brake pedal there is a little mechanism type thing that goes bad after a while (as so many car parts do), it's a switch that goes on your brake pedal arm and when you press your brakes it sends the signal to your lights (you can see it easily, there's one cotter pin and a wire to take off). So pluck up your courage, head down to Pep Boys, spend $10 on the brake light switch and then take five minutes of your precious time to install it. Then strut around for the next day because you fixed something on your car, you stud.
Old 06-24-2004, 08:50 PM
Re: No Brake lights
BigBadWimp..........
Thanks for your suggestion.......I now have Brake lights!!!!! AND my girlfriend thinks I'm a genius!!!! I love this forum!!!! HMmmmm now I need to find a forum like this for motorcycles.
Biker
Old 11-14-2004, 01:38 PM
jimmcse jimmcse is offline
Re: No Brake lights
i have the same problem but switch appears to be good, reason is cause top brake light works. Any ideas?
Old 04-11-2005, 06:20 PM
cryotek cryotek is offline
no brake lights but 3rd brake light works???
Did anyone find the fix??? I have a 95 that is doing the same thing??? any help is greatly appriciated.
Old 04-11-2005, 06:33 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: No Brake lights
Read 2 and 3 posts above yours. Fix is there.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-11-2005, 09:21 PM
Question Not the switch on brake pedal, lamp out module?
the switch is good. THe third brake light still works and I can hear the relay module in the engine bay next to the battery click when my wife steps on the brake. What about the "lamp out module??" Where is it located???
