Old 01-25-2002, 09:30 AM
94civic's Avatar
94civic 94civic is offline
SOHC Turbo Help
I planning on turboing my d16z6 motor but i want to know what i need to beef it up so that it doesn't blow up. Does my motor already come with low compression and if i do need to change my internals what site can i go to to order them. This is the turbo kit i'am planning on buying.
http://www.rollhard.com/apexturbointercooler.htm
Old 01-25-2002, 11:15 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Re: SOHC Turbo Help
You can turbo a stock motor just fine...
Its when you want to go above like 8 psi of boost and stuff that you need to really look at what the hell you got going on in the motor. So if you are going for 6-8 psi of boost, dont worry about your internals ~ less they are shot anyways
AF's Official Asshole
RIP AUNIE
Old 01-25-2002, 12:15 PM
94civic's Avatar
i'm going to be runnig more than that, maybe like 12-16 psi. i know i have to change the pistons, rods, valves, valve springs, retainers and resleave the cylinders . anyone know where i can find these parts for cheap on the net
Old 01-25-2002, 06:14 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
check out www.theoldone.com, they have endyn rods for pretty cheap, actually they have pistons and anything you could need for you D16 really.
Old 01-26-2002, 12:21 AM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
get some rods and pistons...9:1 or so..maybe half a point higher....you can run 10psi on a stock motor, just make sure your engine is still good and take it to a reputable tuner. if you want to go any higher than 10psi, I would start to look into building the bottom end.
FS: Sohc Turbo Kit + misc turbo parts, HMT!! QuikShifter Classifieds 2 10-18-2006 10:58 PM
Cam Sprocket on SOHC Turbo? Frostbyte Forced Induction 1 10-16-2002 12:59 PM
sohc turbo or ls motor/gsr tranny excivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 09-14-2002 07:39 AM
240sx DOHC SOHC turbo manifolds and intercoolers iboost 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 08-27-2002 07:12 PM
sohc turbo hondatool Forced Induction 10 06-13-2002 11:56 PM
