Old 06-21-2004, 02:30 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Transmission Fluid Type?
I need a recomendation as to what I should use for trans fluid. Mods in sig. Trans is an 89 AOD, built up for street strip by myself. Dynamic 3300 Lockup, new clutches, steels, seals, shift kit, deep pan, b&m supercooler, mechanical diode, etc. I was using B&M Trick Shift non/synthetic, but I'm not sure about it this time. Any opinions?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 06-21-2004, 09:18 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Transmission Fluid Type?
Lucas and Redline I've heard are good.
Old 06-21-2004, 09:21 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'd say Redline, Royal Purple, Then B&M synthetic
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-31-2004, 01:13 PM
Notchstang8890 Notchstang8890 is offline
b&m TRICK SHIFT IS GOOD STUFF, USED IT IN MY C4...althought i converted to type-f...thats would ford calls for in almost all its automatic trans...its good stuff man lots of brands make it. a couple cap fulls of type f can be poured into your engine to to quite up valve taps
