Old 01-24-2002, 04:37 PM
Xplocivic's Avatar
Xplocivic Xplocivic is offline
Send a message via AIM to Xplocivic
Anyway to reset the SRS light?
My SRS light is on, do you guys know how I can reset it? It came on when I was installing my ignition, go figure!? Its really annoying now, and I don't have the money to take it to Honda so they can charge me $200 to reset a stupid light. Thanks.
Boosted Civic, 211hp on stock D16z6
Old 01-24-2002, 06:36 PM
Rice-Rocketeer Rice-Rocketeer is offline
If you're SURE there's nothing wrong with the system, just disconnect the battery for a few minutes. If the system is fine then it'll just eventually turn off by itself.
Old 01-24-2002, 07:40 PM
Xplocivic's Avatar
OK, I'll try that, thanks.
Old 01-24-2002, 08:20 PM
praxis praxis is offline
SupplementalRestraintSystem
Better safe than sorry. (you surely don't want the air bag to pop out when you hit a bump, while driving down the road.) I think you should get it checked out.
You have an ECU back-up fuse. (Check your manual). It will be located in the fuse box, in the engine compartment. With the engine and key off, pull it out. Wait 10 seconds and put it back in. If the light comes back on...you should hook it up to a computer (or if you know how to read the self diag. codes, do that...I think you can read the SRS codes that way) and find out what the code is.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
How does one reset the SRS (airbag) light? 91-93-96Geoman Metro 5 03-22-2011 12:56 AM
Resetting the SRS warning lamp singring 3 Series 1 11-24-2005 08:14 AM
how do you clear the SRS Light Gater Galant 0 10-12-2003 11:53 PM
How do you reset the ABS light on the Diablo? modman Diablo 2 06-04-2003 10:36 PM
