Old 01-23-2002, 08:42 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Whats Wrong wit my auto?
hey guys, i need some help.
when im accelerating in my car in 2nd gear at about 2800rpm just before third gear ingages, the rpms jump to around 3250-3750rpm hangs for 1-2seconds then upshifts to 3rd gear. Whats the deal, am i losing my tranny or what?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-23-2002, 09:12 PM
praxis praxis is offline
That IS the tranny slipping.
First step is to check your fluid level (make sure you have enough but not to much). You want to check the level with the vehicle running and in Park or Neutral.
Second step (if proper fluid level doesn't help) is to have a 'transmission service' performed. (change trans. fluid, change filter, replace pan gasket, maybe add a trans. conditioner). If this doesn't help...time for a transmission rebuild. (most likely).
If this doesn't help, you will want to take it to a transmission SPECIALIST.
How long has it been like this?
It is VERY important that you do this ASAP...the longer you let it go, the more of a chance you are taking with your transmission.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 01-24-2002, 12:31 AM
CivicOwnage CivicOwnage is offline
I agree although i would try taking it to a specialist first and have them put it on a diagnostics computer, cause my tranny was dying i went to 6 mechanics and they said it was slipping but couldnt tell me exact problem so i just put it on a computer diagnostics, to get the full problem like ecu, or engine, or internal tranny problem.
Old 01-24-2002, 12:32 AM
actualy check the fluid first then specialist sorry. In my opinion i wouldnt change anything having to do with it just yet cause it might not be the problem i would just pay the 0-50 bucks for a computer diagnostics
Old 01-25-2002, 12:12 PM
crxlvr's Avatar
well thanks for the replies guys, the thing is it does this sporadically not all the time like if im driving in 2nd at about 2500rpm it shifts to 3rd no problem, but if im driving in 2nd at 2800rpm then it holds at 3500rpm then shifts, the fluid is fine, i cant even remeber if i did have the filter and gasket replaced i gotta check my records.
Could the cold weather in my area have anything to do with it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-26-2002, 01:19 AM
ShockJon ShockJon is offline
If you have to rebuild get this www.levelten.com kit!!! I have heard nothing but good about this!!! I am going to do this when I get the money and my auto is running perfect!!! knock
wood!!!
what wrong wit my clutch red_armie_soviet General 2 11-25-2007 09:04 PM
What is wrong with auto manufacturers? Galuple Car Audio 1 10-03-2006 12:59 AM
whats wrong wit this picture killasmilez Street Bikes 3 04-20-2005 12:37 AM
whats wrong wit bcbosley Off-Topic 0 02-17-2004 12:46 PM
whats wrong wit my max? 97wvmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 8 11-25-2002 12:16 PM
