Old 01-23-2002, 08:23 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Turbo/Supercharger question
Just curious about something. I know how both work, so I'm not asking that. My question is does a car with forced induction run "leaner" than a car with out? Both allow more air into the engine, so is the engine leaned out or what?
Old 01-23-2002, 08:57 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Yes, it is a probability. NA carbs/injectors do have some reserve built into them, but if you're really pushing the boost up, they will run out of potential (BOOM!!!!). That's why you can often read/hear about bigger injectors.
Old 01-24-2002, 01:34 AM
texan's Avatar
texan texan is offline
Writer Mod
Re: Turbo/Supercharger question
Not if it's tuned properly. In all likelyhood, if it was an NA car from the factory it's now running more rich in an optimal state of tune (for power production), since boosted motors like a slightly richer mix. All the dynamic compression begs for a little extra fuel over the optimal NA ratio.
'03 Corvette Z06
'99 Prelude SH
Old 01-24-2002, 11:35 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Only if you slap the Turbo/Super on and don't change the fuel to air ratio.
Old 01-25-2002, 10:06 AM
SaabJohan SaabJohan is offline
No, it doesn't. They use a fuelpressure regulator wich increase the fuelpressure when the boost comes. With a standard regulator, let's say 1 bar boost pressure and 3 bar fuel pressure at no boost. When the boost rises to 1 bar the fuelpressure will rise to 4 bar. With a progressive regulator with say 1.2:1 the pressure will be risen to 4.2 bars.
But if you tune the car more than the injectors/fuelpump can handle it will be leaned out. But with the right stuff it's not a problem.
turbo/supercharger questions SlammedCivicSedan Forced Induction 13 06-05-2002 09:08 PM
RSX-S Turbo/Supercharger kits EJ25STi Forced Induction 2 04-29-2002 03:43 PM
N20/Turbo/Supercharger - Reliable? EG Head Forced Induction 2 03-08-2002 10:40 PM
Turbo/supercharges for IS 300??? ShaDoWxKiD IS200/IS300/IS350/Altezza 6 02-28-2002 09:04 AM
turbo, supercharger, and NOS D-Loc Forced Induction 19 02-23-2002 11:43 PM
