Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-22-2002, 10:44 PM
Davidov Speed WRC Davidov Speed WRC is offline
Send a message via AIM to Davidov Speed WRC
Unhappy Heavy, Stiff Clutch
For a while now my clutch pedal(on my 86 Civic)is extremely hard to push in, its almost like a weight machine.
I checked my Haynes manual and it said it could be due to the cable binding.
Does anyone know what it could be? Or if you have a 3rd Gen Civic/CRX, has your clutch, or clutch linkage ever given you trouble?
Old 01-22-2002, 11:03 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
I knew a couple people who've had the stiff clutch problem. All they/their mechanics had to do was adjust the clutch linkage and they were happy campers.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 01-23-2002, 12:00 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Dont know about the 86 civic but on the CRX you can see the clutch cable running right to the tranny and it's adjustable by just turning it. Dont know if this helped ya out or not.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 01-23-2002, 12:09 AM
89ssgti's Avatar
89ssgti 89ssgti is offline
could be your clutch cable starting to seize in the envelope or could be the pressure plate on the clutch that's broken.
But I'd start by adjusting the clutch.
Old 01-23-2002, 01:36 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Start by adjusting the cltuch. On my SiR there is a plastic knob on the G/box that the cable runs through, you can turn it to adjust any slack in the cable, Im sure the USDM cars have the same setup, if not it will be a couple of nuts that you can undo and wind up, the same the throttle cable.
You want to leave some slack in the cable, leave about 1/8th of an inch's movement in the clutch lever under the cable, it donst have to be exact, just so the cable dosnt have any tension when the pedal is out.
If this dosnt solve the problem then you need to look at prehaps discontecting the cable at the clutch end, if its still tight then the problem is in the cable or pedal. Replace the cable, and lube up the pedal. If the cabel moves easily and freely, (dont push down fast on the pedal you might lose the cable end) then the problem is in the clutch itself, and it means replacing the clutch.
Old 01-23-2002, 02:11 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
It's the same with both the B16A and D15/D16 gearboxes. Just a screw setting (better than the circlip on on 1G and 2G civics). My guess it that the clutch itself has issues though. Could be the thrust bearing if it has jammed or siezed to the input shaft.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 01-09-2005, 12:55 PM
PeterJ PeterJ is offline
Re: Heavy, Stiff Clutch
I just found the sight and am an impressed FNG. The problem with your pedel is a dirty cable. take the cable loose from your pedel after releasing all the adjustment from the other end,after you pull the cable through the fire wall suspend it from the hood and keep spraying WD OR any good light lube down the wire rope,it will take time.after you work the cable free back and forth use speedometer cable lube so this wont happen again.
Old 01-09-2005, 05:47 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
http://www.automotiveforums.com/vbul...d.php?t=343505
check your dates
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-12-2005, 06:01 AM
87civicfranky 87civicfranky is offline
dude..this is old....
Old 01-22-2005, 09:09 AM
adaly86 adaly86 is offline
My garage said my cars clutch was 10 times stiffer than it should be they adjusted it and it made it way lighter but then it had trouble changing gears so they adjusted it back, aparently the whole clutch is just seized so im going to have to get it overhauled
Stiff clutch, my knee is about to go... zesty Swift 0 03-08-2006 05:04 PM
Stiff Clutch (Lower Petal Engage) litmag Sierra 0 05-18-2005 01:06 PM
Stiff clutch wac081 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 04-27-2004 01:06 AM
Stiff clutch timos 911 1 08-14-2003 07:07 AM
