Old 06-07-2004, 08:44 PM
z24caviman z24caviman is offline
Send a message via Yahoo to z24caviman
transmission pros please help
i am in the process of putting a used tranny in my 2.3l 4cyl mustang and when i get the tourqe converter bolted to flywheel and trans bolted to the motor the motor will not roll over i tryed turnng over by hand turning and drive shaft still feels locked up when trans is seperated from motor motor rolls over fine ang the middle gear beyond the tourqe converter mover with some force any sugestions
Old 06-07-2004, 08:59 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: transmission pros please help
Your first mistake was bolting the converter to the flywheel. Doing this can damage the seal to the front pump on the tranny when trying to bolt them together.
You will need to install the converter onto the input shaft of the tranny. There are splines that the converter needs to lock onto. You may need to lift and turn the converter a few times to find the splines where they slip together. If the converter is not mounted correctly, the transmission will bind up like you are dealing with.
After that, you can then bolt the tranny up to the motor, making sure to line the converter bolt studs up to the flywheel.
Hop that was clear enough for you.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 06-08-2004, 12:41 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Like Craig said you need to put the convertor into the tranny and then bolt it all together like that. Example is the 5.0 AOD convertor needs to actually been put on turned it will drop, then turned again till it drops again. Then one more time it has 3 "clicks" so to speak.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-08-2004, 02:56 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Also, when the tranny is tight against the engine...Grab a converter stud, give it a quick wiggle. It(the stud) has to wiggle back and fourth within the hole in the flex plate. If it don't move freely then still not good.
You may have already "crashed" the pump though.
Old 06-08-2004, 03:29 PM
ok that is good advice but it still is bound any other sugestions
Old 06-08-2004, 09:01 PM
351wStang's Avatar
351wStang 351wStang is offline
Did the converter come "un-set" when you where bolting it in?
Old 06-11-2004, 01:55 AM
no it didnt come un set. could the tranny be froze?
Old 06-11-2004, 10:43 AM
RexNfx400's Avatar
If it won't come out of the tranny, then the pump has been "crashed" And the pump gears are stuck to the converter.
The pump needs to come off and at least have new pump gears. If the hub on the converter is out of round, you'll need a new or rebuilt converter also. Or used.
Couple of prybars and you should be able to get the converter out, hopefully.
