Old 06-06-2004, 05:19 AM
chinesechickens's Avatar
chinesechickens chinesechickens is offline
Unhappy help!
i masked off the trim aon my hilux body and srayed it satin black. everything was fine and dandy until i took off the tape....
the F*&%ing stuff pulled the paint and primer off.
the paint was tamiya italian red (4 coats) and primer 2 coats.
the tape i used was tamiya.
anyone know why the f*&% this happened?
Estella warren is hot!!
Power is nothing without control
I thought i saw a v-spec II, i did i did. i did see a v-spec II!
Old 06-06-2004, 05:26 AM
labandabonnot's Avatar
labandabonnot labandabonnot is offline
Re: help!
Did you let the paint dry enough before masking? Two days to one week seems to be the time needed for the paint to dry completely... Has the body been washed before primed (better adherence)?
Well, that sucks... Just a little "castrol bath" and "do it again" paint... Sorry!
Back to life soon...
Old 06-06-2004, 05:34 AM
i did wash the body prior to priming....
the paint had dried for 2 weeks before i masked it.
i think somebody cursed this build cos ive had so many problems with it
oh well into the castrol it goes and another R56.00 for another can of paint....
Old 06-06-2004, 08:11 AM
lotusmark2's Avatar
lotusmark2 lotusmark2 is offline
Re: help!
I tend to rough the body VERY slightly to give better adherence use 2000 grade wet and dry, it also makes sure all in release agent is off the body.
Old 06-06-2004, 10:35 AM
Renegade's Avatar
Renegade Renegade is offline
Send a message via MSN to Renegade
Re: Re: help!
You got the point bro'. I'm using this method also. Got some striped paint by masking tape. If there will be a lot of masking I also use transparent primer.
Old 06-06-2004, 11:10 AM
freakray freakray is offline
AF Modelrater
Re: help!
I still can't get over the cost of Tamiya spray in South Africa now.....
AF User Guidelines
Old 06-06-2004, 11:49 AM
yeah i know, its ridiculous isnt it?
too many middlemen.......
oh well
thanks for the help i.ll try the sanding trick
