Old 06-04-2004, 01:58 PM
DiecastCustomz DiecastCustomz is offline
Send a message via AIM to DiecastCustomz Send a message via MSN to DiecastCustomz Send a message via Yahoo to DiecastCustomz
1/18 Maisto 350Z (and mostly all Maisto) wheel removal
1/18 Maisto 350Z Wheel Removal
REAR
1. Remove the muffler by popping it out with a flathead screwdriver:
2. Remove the exhaust pipe going down the middle of the car with flathead screwdriver:
3. Remove screws that hold in rear axle:
4. Remove the piece that holds in the rear axle:
5. Remove the rear axle:
6. Find a screwdriver that will fit snug in the hole where the screw goes in the axle:
7. Use the screwdriver for leverage and pull the wheel away from the axle. (*PULL IN OPPOSITE DIRECTIONS DO NOT BEND OR TWIST OR YOU WILL BREAK THE AXLE*):
8. This it what you should end up with in the end (If you don't break anything):
9. Repeat Step 7 for other side.
10. Put the rear back together.
FRONT
1. Remove the screws that hold on the front wheels:
2. Pull out the piece that holds the front spindles in place:
3. Pop the piece that connects the steering wheel to the wheels:
4. Pull out the front wheels:
5. Separate the spindle from the steering link:
6. Get a screwdriver that will fit in the hole for the spindle:
7. Use the screwdriver for leverage and pull the wheel away from the spindle. (*PULL IN OPPOSITE DIRECTIONS DO NOT BEND OR TWIST OR YOU WILL BREAK THE SPINDLE*):
8. This is what you will end up with:
9. Repeat step 7 for other spindle.
10. Put it all back together.
Old 06-04-2004, 02:13 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: 1/18 Maisto 350Z (and mostly all Maisto) wheel removal
I just added this to the tutorial depository.
-Mike
Old 06-04-2004, 04:43 PM
FlySkyline's Avatar
FlySkyline FlySkyline is offline
Send a message via AIM to FlySkyline Send a message via MSN to FlySkyline
gotta love them percision screwdrivers. nice tutorial too
Old 06-04-2004, 06:37 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: Re: 1/18 Maisto 350Z (and mostly all Maisto) wheel removal
Nice work. You trim those fingernails too close though. Your mother wouldn't be proud.
Old 06-04-2004, 11:41 PM
sky-raptor sky-raptor is offline
Where can I get those screwdrivers?
Old 06-04-2004, 11:47 PM
They are from CRAFTSMAN, got them at Sears.
Old 06-05-2004, 12:00 AM
Hey, how come your not on AIM
Old 06-05-2004, 10:08 AM
mike@af's Avatar
Re: Re: Re: 1/18 Maisto 350Z (and mostly all Maisto) wheel removal
Use private messaging for personal communication.
Go to Sears or Ace Harware for the screwdrivers.
-Mike
