Old 06-04-2004, 11:27 AM
mel_carramel's Avatar
mel_carramel mel_carramel is offline
Send a message via MSN to mel_carramel Send a message via Yahoo to mel_carramel
Unhappy Help~!!!!!
please anyone~!!!
help ME!!!! i need to know how to strip off paint from my Nissan Skyline~!! Helppp~!!!
Just for ya'll Information, ive already paint undercoat.. which is primer white... and italian red.. all tamiya products...
PLEASSEEE HELPP MEEEE
Old 06-04-2004, 11:28 AM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: Help~!!!!!
give it a bath in Castrol Super Clean.
Old 06-04-2004, 11:32 AM
Re: Help~!!!!!
what is castrol super clean?
where do i get them?
what do i asked?
Old 06-04-2004, 11:34 AM
freakray freakray is offline
AF Modelrater
Re: Help~!!!!!
Stripping paint is covered in the Car Modelling FAQ.
AF User Guidelines
MR2_Lancer MR2_Lancer is offline
Send a message via AIM to MR2_Lancer
Re: Help~!!!!!
the faq could answer that question. but ill be nice...go buy some castrol super clean and soak it for a bit, then the paint will rub off. make sure you wear gloves though. if you want the full story, check out the FAQ
GreG
Old 06-04-2004, 12:32 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Hang on, hang on.
Which Tamiya procucts? Tamiya acrylics, or Tamiya spraycan laquers? I suspect that it's the latter? CSC doesn't tend to work very well on laquers. It may work right now, if the paint hasn't had a chance to fully cure- but there are other options. 91% isopropyl alcohol works very well to strip Tamiya laquers. Its availible nearly everywhere in grocery or drug stores. It's really cheap, and safe to handle (apart from being flamable). The best way to use it is to find a plastic container with a cover that the body will fit into, fill it with the alcohol, and soak it overnight. I use a 1 liter container that I got filled with wonton soup from the corner Chinese takeout. (It has to have a top, because the alcohol will evaporate quickly if uncovered). An old toothbrush will help scrub off any stubborn spots. This will take off both the paint and primer, but if both are Tamiya laquer, you can't strip one and not the other.
People will also tell you that brake fluid works, but I prefer not to mess with it. If you do, make sure you dispose of it safely, in accordance to local and national laws.
Old 06-04-2004, 08:33 PM
Re: Help~!!!!!
Coolie~! Thanks All you guys~!
