Go Back   Automotive Forums Car Chat > Porsche > General Discussion
Old 06-02-2004, 11:29 PM
MatobaImportRacing MatobaImportRacing is offline
Send a message via MSN to MatobaImportRacing
what porsche engine to use in a sand rail?
what is the best air-cooled porsche engine to use in a sand rail?
Old 06-04-2004, 12:04 AM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Typically, the 356 or 914 2.0 would be the hot ticket to have, for most VW based rails. If you're building it from the ground up though, I would suggest a flat six, but they can start getting expensive. No such thing as a cheap 911
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 06-04-2004, 08:56 PM
83-944 83-944 is offline
Re: what porsche engine to use in a sand rail?
It all depends on your budget!!
356 engines are getting exp[ensive to rebuild.
914 engines are Type 4 VW engines. Relatively cheap parts, massively upgradeable.
911 engines weigh a awful lot more than any of the others. You'll need a supplemental oil cooler system, parts are very expensive, you'll need an oil tank cause it's dry sump, yada yada.
If you got the money, go 911, IIRC a 2.7 should bolt right on to a T2 tranny.
Less money is to build up a T4 engine, it's reliable, less work, no main oil hoses to break/leak.
Good luck!
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
