Old 06-01-2004, 10:47 AM
burly94gt burly94gt is offline
cam swap
is it possible to do a cam swap w/o pulling the engine??
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 06-01-2004, 12:33 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Sure, but you'll probably have to pull off the front grill, radiator, etc to do so. Never worked on a 94/95 though, so I couldnt tell you for sure.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 06-01-2004, 01:45 PM
Re: cam swap
cool...thanx for the response!
Old 06-01-2004, 03:08 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Yes it definely can be done you just need to pull like said the fan, radiator, A/.C all the stuff upfront to have room to pull the cam out.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-01-2004, 09:29 PM
Re: cam swap
im gonna be swapping out pretty much the whole topend of my motor (upper lower heads tb and the cam)...would you guys suggest pulling the motor or doing all of the swaps w/ the engine still in the bay....thanks
Old 06-02-2004, 12:24 AM
Re: Re: cam swap
It really depends upon you. Some people like to pull the motor for the simplest work cause its less of a hassle than leaning over your fenders constantly. In your case, however, unless your motor mounts are bad I'd do it in the car personally
Old 06-02-2004, 01:15 AM
GTStang's Avatar
Stang Guy
I'd just do it in the car also.... not much ease gained from pulling it out especially when it's a EFI car.
