Old 05-31-2004, 06:55 PM
eillob's Avatar
eillob eillob is offline
Battery in the Trunk
I was watching a show on Spike Tv and one of the projects they had on was mounting the battery in the trunk. Has anyone tried this and is so what do you think.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 05-31-2004, 07:19 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Battery in the Trunk
Its a great relocation. Better weight distribution for launching and more room under the hood. They sell kits in Summit.
Old 05-31-2004, 09:24 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
I'll let you know how it goes when I do it in my coupe, I should be doing it with in the next couple weeks.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-31-2004, 11:47 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
I've done it in my '69. Its easy. Considering the size of my battery, it shifted a lot of weight back, which should help launches. I used the Summit kit, then went to my local autoparts store and stuffed the biggest battery I could fit in it. That way i didnt have to use any of the crappy brackets and stuff that comes with the box!
Old 06-01-2004, 12:36 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: Re: Battery in the Trunk
Yeah HiFlow, definitely let me know how it goes. I'm interested in doing that myself. I was also thinking about doing the 3G swap during the process. Are you using the summit kit too?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 06-01-2004, 03:15 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I've done 2 of them for 4.6 cars while installing the Vortech kit with the liquid aftercooler so the battery has to be moved. Both times I used Taylor's kit. It runs about $100 bucks but comes with everything and a very nice billet battery box unlike the plastic one in the Summit kit.
Install it's not very hard just a tad time consuming but nothing really troublesome. Advantages are weight distribtuion but nothing your drastically going to notice until you are at a higher level in drag racing or autoX. Plus note it helps unclutter the engine compartment which is nice.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-02-2004, 02:35 PM
duplox's Avatar
yes, getting hte battery out of the engine bay is a big plus... made room for my turbos!
