Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-19-2002, 12:35 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Swapping gears question!!
hey guys, my friend is getting a motor swap in his 89 civic hatchback DX 5 speed.. and im wondering if im able to swap out his reverse for mine since that mine isnt working. is this possible or does the entire transmission need to be swapped out?I have a 90 crx si.thanks!
Old 01-19-2002, 01:44 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
To swap the reverse gears,you would have to take out the tranny and open it up to have access to the gears.
Unless you have already done this and know for sure that the gears are the same,I say don't do it,just swap the tranny.
Old 01-19-2002, 02:10 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Unhappy Swapping gears
I believe you can just take the tranny apart and take his reverse. If he's getting a new motor, why dont u just take the whole tranny?? or did i misread it?
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 01-19-2002, 05:04 PM
mellowboy's Avatar
Well no u read it rite man...Is my car gonna be slower if i use the dx tranny..cause i like my high gearing
Old 01-19-2002, 05:05 PM
mellowboy's Avatar
Oh i forgot to add this...yeah he is gonna give me the whole thing!
Old 01-19-2002, 05:21 PM
89ssgti's Avatar
I'm not sure but maybe the diff gearing is higher on the dx,meaning you'll rev less on the highway and have a higher top speed,but I'm not sure about that.
Old 01-19-2002, 05:33 PM
90CRXZCSi's Avatar
Unhappy gearing
I think you will have more top speed yeah. I hit 80 MPH in third while my friend in his DX hits well over 92 MPH. So i guess in a way it could make it slower but you would be able to keep the speed in each gear longer. Im not real sure though.
Old 01-19-2002, 11:23 PM
mellowboy's Avatar
Yeah as long as it bolts up to my si motor i guess i won't sacrafice that much power? Hey would it be better on gas though? Well this is only temprary anyways. I have my b16 sitting here waiting to be install but i still gotta wait for Spring time and wait for like wiring harness etc...
Old 01-20-2002, 11:20 AM
mellowboy's Avatar
Ok i told this guy that i'm getting a dx tranny for free. He said he thinks it won't fit cause its a 1.5 liter? I told him all d-series should fit. Its from an 89 hb. I just wanna make sure if it does fit...so is he rite or wrong?
Old 01-20-2002, 11:23 AM
89ssgti's Avatar
D-series are interchangeable,except for 88 which had different input shaft spline,if I remember correctly.
Old 01-20-2002, 12:09 PM
mellowboy's Avatar
But i can still switch gears from it rite? Cause i really need that reverse!
Old 01-20-2002, 12:14 PM
89ssgti's Avatar
would be easier to swap the whole tranny.
Old 01-20-2002, 01:12 PM
mellowboy's Avatar
Yeah i just wanna double check if my friends is an 89 hb.But if its an 88 then i'm just gonna get his reverse?
Old 01-29-2002, 08:45 PM
josecrxvtec josecrxvtec is offline
dx tran vrs si tran
hay just get the revers gear ur 1/4 time will be higher with the dx trans the gears are to long si are short and will pick up faster than the dx the revers gear should swap theres no difference in them only the forward gears and the final drive are diff iff im wrong corect me
Old 01-30-2002, 07:53 AM
mellowboy's Avatar
Yeah another friend of mine says he has a 91 si trans. So he's gonna give it to me but the thing is i think he said the bell housing is chipped so he's gonna switch gears for me. I told him that my 2nd ,3rd and 5th gear is bad also. So i guess we gonna switch all those gears also plus with a jdm final drive ratio of 4.44
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
gear question punkska8 Grand Cherokee | Grand Cherokee SRT8 0 12-18-2003 06:33 PM
CRX SiR First Gear Question? wikedcrx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 07-12-2003 11:06 PM
tranny gear question Jay eS Iye '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-29-2003 02:04 PM
