Old 04-28-2003, 04:57 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Question tranny gear question
i was driving a couple days ago, and i had some pressure on the shifter on second and i pushed up on it and it moved from 2nd into neutral. this is my first standard car, so it this normal or something wrong?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 04-28-2003, 05:16 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
Re: tranny gear question
if you push on the shifter, it will move...
Old 04-28-2003, 10:08 PM
Jay eS Iye's Avatar
so it will move out of gear without pushing the clutch?
also kinda O/T, what will help the shifter from wobbling back and forth?
Old 04-28-2003, 10:12 PM
KeGrO KeGrO is offline
Banned
Send a message via AIM to KeGrO
im not really sure what its doing to your car, but until you find out, i advise you NOT TO DO THAT ANYMORE! ! it might wear you clutch out faster. . . does anyone really know what it does?
Old 04-28-2003, 10:46 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Ummm the shifter popping into N without you touching it is a bad sign.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-28-2003, 11:06 PM
jusg19 jusg19 is offline
the shifter should and can move out of second or any gear is you push on it at the right rpm.
for instence...if youare accelerating and its in second you can push the shifter out of second with out the clutch , but getting it into 3rd w/o the clutch is alot harder because you have to rev match it and if your wrong you'll grind the gears.
the wobbling thats another issue
Old 04-29-2003, 09:38 AM
Jay eS Iye's Avatar
no no, i am touching it, in fact i was pushing up slightly, didn't mean to but it freaked me out... but i didn't try to push it into 3rd, i could just imagine the grinding that would make... for hte wobbling, i'm kinda thinkin its the bushings or something
Old 04-29-2003, 02:35 PM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
My friend had a cheroke and showed me how he shifter without using the clutch. Didnt really trust it. Also, if you grind it, you WILL hear and feel it. It sucks!!
Old 04-29-2003, 03:04 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Getting it out of gear is easy...and isn't really an issue...it is a lot easier when the engine isn't under load (i.e. light to no acceleration) - stuffing it back into gear without the clutch wears out the synchros, but is nice to know how to do if your clutch ever fails (cable breaks, etc.)
The wobbling is the rear joint bushing & bolt under the car that connects your shifter to the shift rod. You can tighten it up a little, but if you get it too tight it won't slide and pivot correctly when you move the shifter....You really should remove the shifter, and unbolt it from the rod, and rebuild the bushing (there is grease and rubber o-rings and stuff inside the bushing), or buy a $30 short shifter at the same time. Most (but not all) come with fresh bushings, (my B&M re-used the bushing, but gave me grease and new o-rings ) then you just need to tighten it right so it is not loosey goosey, but still moves freely.
The shifter arm sits inside the shift rod fork, and when you tighten the bolt the rod fork gets squeezed and makes it feel tight...our 12+ year old cars tend to have a little play in them and it feels sloppy, sometimes tightenting that bolt a little helps..but again, not too tight, or it will be hard to move..
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
