Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 05-25-2004, 08:12 PM
tupac tupac is offline
LT1 stroker can i spray it or turbo?
hey guys i need help here i got a 96LT1 motor bore .60 over and i want to know if i can still spray NOS os maybe a turbo or a supercharger are the cylinder walls too thin? or is it ok as long as it has a good bottom end people has told me that cylinder walls are to thin to for any of those above to keep it all motor what you guys think?
Old 05-25-2004, 09:11 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
First off, unless you're motor has a larger crank (i.e. 3.75" stroker crank as opposed to the 3.48" stock stroke) you're not a stroker with a .060" overbore. But you are at 360ci now, 10ci helps out.
If your pistons, rods & crank are forged, add the juice and/or the boost. Lots of racers go straight for an over bore on the block. Add's more displacement, thus more power.
If you're running stock style oversized pistons, you can run a small shot of nitrous or small amounts of boost. Forged internals are your best friend.
Good luck.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 05-25-2004, 09:24 PM
Re: LT1 stroker can i spray it or turbo?
hey redneck383 i have a all forged assembly 5.750 crank for a stroker forged pistons and rods so u think i can still put a turbo or supercharger the walls are not to thin for that can i spray it is it safe ?
Old 05-26-2004, 12:57 AM
-The Stig-'s Avatar
On Fire!
I think you ment 3.75" crank...
But if you've got a fully forged bottom end, you can slap on a turbo/supercharger system and run moderate boost. I'd guesstimate at about 9-11lbs.
Or you can use a fair amount of Nitrous by itself... like a 125-175 shot. I'm not well educated on nitrous shots, but Self (fellow member on AF) was running I believe a 200+ shot on a stock bottom end. I'm sure you can safely run a 200 shot.
I wouldn't suggest running both a Forced Induction system and nitrous shot... if you do, use them both in small amounts for the safety of your motor.
Good luck.. have fun.
Old 05-26-2004, 01:08 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
What's your CR with the new crank and rods? That would help a lot in giving you a answer to your question.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-26-2004, 01:12 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
gtstang were you been, havn't seen you around here much. and i like the sig kill count thing.
i would copy but i don't know were i'm at in kills
Old 05-26-2004, 01:18 AM
the compression on the motor is 11 to 1
Old 05-26-2004, 08:23 AM
xAUTOxRACERx's Avatar
xAUTOxRACERx xAUTOxRACERx is offline
If you are sure it is an 11:1 You could add an induction kit with moderate boost as indicated by redneck. But what I would say is add some juice to it instead. Less maintenance and easier on you motor since it is only used when wanted!
Old 05-26-2004, 03:45 PM
GTStang's Avatar
Stang Guy
I've been around here and there. Haven't had much time for AF lately. Look in my gallery and you can see why LoL. Love the Silver Vette in your Sig Pic.
11:1 Compression street motor on pump gas..... I think you should just leave the FI or Nitrous idea at that an idea.
Old 05-26-2004, 05:14 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Re: Re: LT1 stroker can i spray it or turbo?
I would agree. To run forced induction, you need to have lower compression. 11:1 is high (our race car just has 12.5:1 pistons), and I'd say you'll cause a meltdown with NOS, turbo, or s/c.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 05-26-2004, 06:52 PM
Exactly my point your compression is a little high for induction.
Old 05-26-2004, 07:33 PM
Yeap. NOS would be his best bet, but still yet, if he gets trigger happy on the button/switch then he's gonna blow that motor sky high.
Best thing to do I think would be just keep it NA. Change the cam out, do a little work on the heads and then he won't need the "kick in the ass" NOS gives ya.
**1966 Chevy II**
Old 05-26-2004, 08:35 PM
cndctrdj cndctrdj is offline
Send a message via AIM to cndctrdj
these cars love nitrous.... they hate fi but love nitrous. i have seen people run 100 - 150 hp shots on all stock internals and 160k + milage no problems accept for the rear end(DR's grip too much) id say go for 100 shot. ill get some info for you when iget the chance
95 TA - fast
92 240 - fun
96 prelude si - lots o fun
94 cr500r - rediculously fast and fun
