Old 05-18-2004, 05:17 PM
rv56 rv56 is offline
pilot bushing removal
I have a '67 mustang with a 200 straight 6cyl along with a 3 speed trans. I have to replace the clutch, which is my first time, I have already removed the tranny and need to replace the pilot bushing, but do not know how to remove it. Any ideas will appreciated. Thanks. rv56
Old 05-18-2004, 05:34 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
you need a special slide hammer-lookin tool. you can probably rent one at a local parts store. to install the new one you need a special punch.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 05-18-2004, 06:15 PM
malcolm brumley malcolm brumley is offline
Re: pilot bushing removal
I have seen old timers remove them by packing them with grease and using a dowel rod the size of the inside diameter of the pilot bearing. After packing, insert the rod and hit it with a hammer, out comes the pilot bearing. Also auto zone sells a puller.
macbrum
Old 05-18-2004, 07:13 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I've done it both ways... the bearing grease trick only works if the input bearing is in good shape. Otherwise you need a bearing puller which is a slide hammer with fingers on the end.
To put in the new 1 just use a socket that will work.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-18-2004, 07:21 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Damn, I was gonna say the same thing.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
