Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-17-2002, 06:16 PM
flipkid flipkid is offline
Send a message via AIM to flipkid
lowering springs question
will just using a set of aftermarket lowering springs (no shocks, no coilovers, jus springs) damage anything on a stock suspension?
Old 01-17-2002, 07:34 PM
texan's Avatar
texan texan is offline
Writer Mod
It's very possible you will blow the stock shocks, especially if the springs drop the car quite a bit and/or are much stiffer than stock.
'03 Corvette Z06
'99 Prelude SH
Old 01-17-2002, 07:44 PM
3.5litermoose 3.5litermoose is offline
Send a message via AIM to 3.5litermoose
yep. Definately will have to get some sport shocks from koni or bilstein. Those will run you about 300 bucks.
"Wheel spin in 2nd! 3rd! 4th! OHH!!!"
-Tiff Needles driving the Mclaren F1
Old 01-17-2002, 09:12 PM
Racing Rice's Avatar
Racing Rice Racing Rice is offline
Send a message via ICQ to Racing Rice Send a message via AIM to Racing Rice
and dont go to low.. or youll really need camber kits to help out..
Racing Rice
Cars:
'97 Civic EX, '02 Explorer Eddie Bauer, '99 Isuzu Amigo 4x4
Bikes:
'05 Suzuki DL650 Vstrom, '05 Yamaha Raptor 660R
Old 01-19-2002, 10:07 PM
seriburi seriburi is offline
me = newbie
what are camber kits? what do they do? and how would it help if you go really low on the car?
Old 01-20-2002, 01:34 AM
b16b bomber b16b bomber is offline
cambers help with the alignment of your car
the stock cambers dont have enough adjustability to align the wheels when you car is lowered, so you would have to buy aftermarket camber kits to allow you to have proper alignment
Old 01-21-2002, 01:14 PM
texan's Avatar
Writer Mod
seriburi...
CAMBER:
Camber is the angle the wheel deviates from perfectly vertical when looked at from straight ahead. Positive camber would have the top of the wheel inclined outwards, away from vehicle center, while negative camber has the top of the wheel leaning inwards to vehicle center. Contrary to popular belief, any and all camber angles hurt tire adhesion to the road, and for one obvious reason. Tires create the most grip when they put the biggest footprint onto the pavement possible, and any significant camber angles shrink the all important contact patch. The reason people associate negative cmaber with good handling is because as body roll occurs in a corner, positive camber is naturally imparted to the outside wheels. The suspension's camber angle at static ride height (plus it's camber curve, see below) will determine whether the wheel goes into positive camber during body roll, or simply balances out to zero camber. So just know that ideally we want zero camber at all times, but like most things automotive a compromise must be struck: dial in a bit of negative camber at static ride height for the least amount of positive camber possible at maximum effort cornering.
As you lower a Honda more and more, negative camber becomes an increasing problem. Bad tire wear, poor handling and directional stability can all be side effects of too much negative camber. Honda suspensions also have very limited (if any) camber adjustment, so buying a camber kit is basicaly just buying a greater level of adjustment so you can get the alignment specs correct.
'03 Corvette Z06
'99 Prelude SH
Old 01-21-2002, 01:28 PM
94civic's Avatar
94civic 94civic is offline
how low can you drop a civic without having to use a camber kit
Old 01-21-2002, 01:37 PM
texan's Avatar
Writer Mod
The general consensus is about 1.5" before you start running into problems. 1.7" and you'll probably be alright (it depends upon your specific tire sidewall), 2" and you'll definitely be seeing camber issues.
'03 Corvette Z06
'99 Prelude SH
Old 01-21-2002, 06:59 PM
Also keep in mind that your car comes with a little negative camber from factory alittle bit of negative camber is good. Just try to keep it within factory specs and youll be fine.
Racing Rice
Cars:
Bikes:
Old 01-22-2002, 08:22 AM
nemesls_2000's Avatar
nemesls_2000 nemesls_2000 is offline
Send a message via AIM to nemesls_2000
Re: seriburi...
Originally posted by texan
CAMBER:
Nice info, THANX!!! What are some of the reasons for a tire to cup?
Mods:
AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels.
Old 01-28-2002, 09:00 AM
LX98Civic's Avatar
LX98Civic LX98Civic is offline
Send a message via Yahoo to LX98Civic
I went with Neuspeed sports / Bilstein HD's just for that reason. I do however need to do the old washer and new bolt trick for the rear.
Oh, and the ride is almost like stock.
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77----------------
--- --- --- -- Sleeper in the middle -- --- --- ---
Old 01-28-2002, 10:24 PM
texan's Avatar
Writer Mod
Re: Re: seriburi...
Generally speaking, tire cupping results from sudden and profound changes in wheel location, which is why loose or bent steering and wheel location parts (suspension hard parts, tie rods, etc.) are often to blame. Bottoming out due to extreme lowering with soft spring rates can also be to blame, as well as blown shocks in rare cases. So if you have a cupping problem it's due to something fairly basic not working right, and is definitely affecting more than just treadwear patterns (i.e. performance and vehicle stability).
'03 Corvette Z06
'99 Prelude SH
Old 06-12-2002, 05:23 PM
SlammedCivicSedan's Avatar
SlammedCivicSedan SlammedCivicSedan is offline
Send a message via AIM to SlammedCivicSedan Send a message via Yahoo to SlammedCivicSedan
what does it look like when tires cup?
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 06-13-2002, 07:38 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
WOW! Talking about revising an old thread Have nothing better to do?
http://www.kaltire.com/commercial/me...es/cupping.php
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
lowering springs question... alexmurphy Engineering/ Technical 4 08-25-2010 09:57 AM
Lowering Springs Question Intrepid23 Engineering/ Technical 6 07-17-2010 06:18 PM
Lowering Springs question kujo1717 Tires and Wheels 0 07-28-2004 12:51 AM
96+ Civic Lowering Springs Question 90CRXZCSi Tires and Wheels 5 03-25-2002 09:46 AM
