o/d tranny
just 2 simple questions...what does o/d do, and what is it for?
Not quite sure how to answer. Its 4th gear in your tranny. Overdrive
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
O/D stands for overdrive. It's not really an extra gear. It's a clamp with brake like material which locks the primary drive hub, which then do to they way planetary gears work changes the gear ratio of the tranny.
That is how most O/D's work but then there are OD's like the 4+3 etc..,
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: o/d tranny
In the example of the AOD, a modification for drag racing is to remove the OD specific gearset for less rotating mass and quicker acceleration. You are correct in the fact that when overdrive is selected, a band holds the drum in place, and with the other corresponding clutches applied, due to the planetary gearset drives the output shaft at a ratio greater than the normal 1:1 of a conventional high gear. For an example, the AOD overdrive is at approximately a .67:1 ratio. Meaning that for .67 revolutions of the engine, the driveshaft will rotate 1 revolution. 1985-1993 T-5 standard transmissions operate overdrive at a similar ratio. |
It's not an extra gear in an AOD... if it was truly an extra gear there would be a 4th drum.
Re: o/d tranny
GTstang, if it is something different please show me some text somewhere or something explaning it. |
Re: Re: o/d tranny
The Doug Nash 4+3 used in mid 80's Vettes is a true OD manual tranny. Here is how it works you have a 4 speed tranny. There is an OD unit which is engaged and disengaged by a switch. This unit can be engaged for 2nd, 3rd, and 4th gear lowering the number value of each. These are made up numbers but if 2nd= 2.6 3rd= 1.9 4th= 1.2 with the OD unit engaged 2nd=2.4 3rd=1.6 4th=.8. Now do you have a transmission with 7 gears.... no you have a tranny with 4 gears and a OD unit which can reduce the last 3 gears ratios. I hope this explians to you why.... #1 Wether or not it is an OD, is not determined by what numeric gear ratio it is. #2 That an OD is not an extra gear.
Re: o/d tranny
LOL. wow i dont know how you thought of that, it was kinda confusing to me but anyways. that is just like a gear vendor overdrive unit.but anyways here read this it should help. also im not saying your wrong but im not either. and yes the T56 is an overdrive, that part your are mistaken about.
this is what i ment by showing me some text. this was take straight from a mustang magazines websight. i did a simple search for a mustang magazine ane then did a search on there sight for overdrives. " The automatic overdrive (AOD) transmission first appeared in new Fords and Mercs in 1980 and has steadily improved since. It’s a four-speed automatic transmission where Fourth gear is Overdrive—actually the reverse of what your engine experiences in gears 1 and 2 in conventional automatics." here the link if you would like to read even more. it explanes more. http://www.mustangmonthly.com/howto/33598/index.html edit: and the doug nash 4+3 is not activated by a switch. it is a 4 speed maual with a automatic overdrive. it is probably controled similarly to a automatic trans detent/kickdown/T.V. cable. it disengages the overdrive unit an a certain % throtle. i think you are canfusing an overdrive and a torque converter lockup or something and maybe combining the two. because many TCC untis have a switch that when activated locks up the torque converter in 2nd and 3rd gear as oposed to only automaticaly in 4th, and it is primaraly used for a towing only situation, and like i stated above when the lockup is ingaged it does actualy lower the RPM's by a couple hudred RPM's. on a chevy car or truck the TCC is tied into the brake light switch and if you are driving along in 4th gear just crusing and the torque converter is locked up you can bearly touch the brake pedal so that the lights would come on but not apply the brakes and you can watch the tach or listen and the RPM's should come up a few hundred. Last edited by 68chevelle; 05-20-2004 at 03:12 AM. |
Re: Re: Re: o/d tranny
Direct Drive (4), and Overdrive (5). You have a smaller gear turning a larger gear in underdrive or gear reduction ex. 3:1. You have two gears of equal size (gear on input shaft turning gear on output shaft) for direct drive 1:1. You have a larger gear turning a smaller gear in overdrive .6:1. Overdrive is any time the driveshaft makes more revolutions than the crankshaft. |
Re: o/d tranny
Overdrive is indeed an extra gear in both the T-5 and T-56 Manual transmissions in addition to other manual and automatic transmissions. The T-56 actually has 2 overdrive gears. The Richmond Gear/Doug Nash 5 speed is an example of a transmission which has steep 1st and second gears with a direct drive (1:1) 5th gear. No Overdrive there. |
Re: o/d tranny
overdrive is for increasing fuel economy. to answer your other question.
