Old 05-17-2004, 09:59 PM
dalydude dalydude is offline
Cool Help with an 83
Hey anyone please help if you can!
I have an 83 stang with a 351 stroked to a 396. My problem is I disconnected my battery a while back and then just recently tried to hook it back up. The neg. was connected but when I tried to attach the positive, the starter started revving as soon as I made contact. The engine doesn't turn over, but the car's starter instantly starts without the key in the ignition. Before I tear the whole car apart, does anyone have any ideas?
Thanks,
Dalydude
PS The car also has a MSD6A system with an MSD blaster coil. Could this be affecting it in some way? What about the ignition switch in the column?
Old 05-18-2004, 05:18 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Sounds like your starter soleniod is jumped somehow. Or like you mentioned it could be your ignition switch but usually it turns the car off on you all the time.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-18-2004, 05:39 AM
knucklebuster2 knucklebuster2 is offline
Lightly tap the starter solenoid on the fenderwell. See if that helps. Then replace it.
Old 05-19-2004, 09:54 AM
Mercracer Mercracer is offline
Re: Help with an 83
If you disconnect the small wire ("S" post) from the solenoid, and it continues to stay active, then the solenoid is bad, which luckily is cheap and easy to replace.
