Old 01-17-2002, 02:17 PM
michaelungaro michaelungaro is offline
95 civic projector lights
hey, i jsut got my projector lights in the mail today, and low and behold...no instructions what so ever...
any of you guys know how to install these things....doesn't look too hard, but i don't have much time so i want to get it done right as quick as possible, thanks a lot y'all
cheers
mike
Old 01-17-2002, 02:23 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
Just undo the bolts for your headlight and replace it. if you don't know where the bolts are, look at the aftermarket projector, and see where the bolts would be, then take a socket wrench and unbolt them. I'm not sure if you have to take the bumper off. you do on the 6th gen.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 01-17-2002, 02:37 PM
it's mostly the terminals i'm wondering about...i found that there is a plug-in in each projector lamp, so i'm assuming that the just wire up to the old lamps terminals...hmmm....i'm starting to wonder if i am goingt o be able ot explain...argh....i'll let oyu know
haha
thanks a lot
cheers
mike
Old 01-17-2002, 03:11 PM
Oh, umm, if the projectors didn't come with a harness that splits your existing harness. Your stock harnesss should have three wires. ground (Black), high beam, and low beam. so all you have to do is splice on the wire from the projector lense to the highbeam wire on the stock harness, and on the regular light side, just splice it onto the low beam wire on the stock harness. then, just do the two black wires to the ground.
35% Platinum tint
Old 01-17-2002, 03:47 PM
k, well i got the harness...like i said...the old head lights have a plug in that the new projectors will go into, there by making a spereate high beam and low...ground i know what to do...but there are two red wires with ringlettes on them....are they supposed to hook up to the battery ?
thanks
mike
Old 01-17-2002, 04:31 PM
Xplocivic's Avatar
Xplocivic Xplocivic is offline
Send a message via AIM to Xplocivic
You will have to remove the bumper. Not too hard, there are about 8 screws on top right at the hoodline. in the middle. Then all thats left are the screws that connect it to the wheel well, don't remember how many, only a couple though. Easy.
Boosted Civic, 211hp on stock D16z6
Old 01-18-2002, 01:37 AM
GhettoLegs's Avatar
GhettoLegs GhettoLegs is offline
Send a message via AIM to GhettoLegs Send a message via Yahoo to GhettoLegs
Yeah, remove the bumper.... unplug the wiring.... unscrew the housing.... screw the new housing in.... plug in the harness.... test it out.... put the bumper back on.
Finished product.... a nice mean glare!
I love mine... even though the heat cracked one of the projector lenses and created a weird cats eye effect.
~'93 Civic CX hatchback body~
Tacoma, Washington
AIM: GhettoLegs
What you got? Direct port rice injection? ;oÞ
Old 01-18-2002, 12:18 PM
soul180's Avatar
soul180 soul180 is offline
K, well i got the little bastards installed...
i hooked the 2 power wires straight to the positive battery post, hooked up terminal up to the old head light harness, then also i hooked the new head lights into the old plug-ins. Seems to be working...except i noticed my day time runing lights are the same as my high beams. is this normal and did i just not notcie on my old headlights....please help...thanks
UGSTYLES
Old 01-18-2002, 01:32 PM
Xplocivic's Avatar
Civics don't have "Daytime Running Lights". So what you are saying is that there are lights on all the time? This is wrong. Lights shouls only be on when you turn the dial on the stalk. Maybe you wired something wrong. I don't know why it would be that difficult, mine came with all the connecters and they were just plug-n-play.
Old 01-18-2002, 03:25 PM
t0p_sh0tta t0p_sh0tta is offline
The Canadian civics do.
Old 01-18-2002, 06:20 PM
hatchbacksi hatchbacksi is offline
Send a message via Yahoo to hatchbacksi
yes thats correct, the canadian civics have daytime running lights.
when you turn the car on, the high beams come on, but with less intensity, however, when you put projectors on, the high beams come on like they should, but the brightness is the same as the reg. high beams...
mine does that too, and i have projectors also....
i have a 93 canadian si hatch
Old 01-18-2002, 06:31 PM
mungaro mungaro is offline
so you mean i installed them correctly....can i get a WOOP WOOP hahah
thanks for oyu help guys
"the best thing you can do to your car is learn how to drive it" - me
Old 01-18-2002, 06:37 PM
alright, how that i have them installed....how aobut some bright wihtes/....i'm thinking PIAA's. Anyone had any experience with these?
thanks
Spyder Halo Projector Lights need help adjusting light kojisan Exterior | bodykits | Lighting 13 12-29-2012 01:33 PM
Help!!! How Do I install Halo Projector Lights on a 2001 Honda Civic? tcgrimreaper '01-'05 Civic 2 08-02-2007 10:01 PM
Projector Lights with City Lights rmiessler Camaro Discussions 4 04-09-2007 05:10 AM
Projector lights...92-95 civic gwako Exterior | bodykits | Lighting 11 03-17-2002 06:42 PM
95 civic projector michaelungaro Exterior | bodykits | Lighting 2 01-18-2002 05:04 PM
