Old 05-15-2004, 11:13 AM
superblur superblur is offline
I was just reading "5.0 Mustang and Super Fords" magizine and I just read about this guy putting a 5.4L DOHC engine into a foxbody. I was just wondering how much time and money this would take?
Would it bolt up to any of the engine mounts?
Would you have to do any body modifications?
Would it bolt up to the tranny?
thank you to those who respond!
Old 05-15-2004, 01:16 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: 5.4
Yeah that yellow notch. Thats freakin nice!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-16-2004, 01:01 AM
stang_guy stang_guy is offline
Muscle Mustangs & Fast Fords put a lightning engine in a fox-body mustang a while ago but they had to put a 4" cowl hood to cover the blower and it still stuck out a bit.
Huge ass aluminu rear wing? $250
Chrome coffe can weed-eater muffler? $125
Spanki'n a wannabe import by 28 car lenghts........
PRICELESS.
Old 05-16-2004, 05:30 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
It's has been done before like said wit a lighting motor.
Answers to ya questions are no,some,no.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-16-2004, 10:36 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 5.4
LOL!
no, some, no, maybe, probably not
I didn't see a yes in there. haha
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-16-2004, 11:38 AM
boosted331 boosted331 is offline
Re: 5.4
No, Lots, No
A friend of mine tried to do a 5.4 quad cam swap into his fox body, and it would not clear the shock towers. He eventually went to a 5.4 2V (which is a total waste of time with the shitty flowing modular 2V heads) and he still has almost no room in there. To change cams we couldn't even get the valve covers off without jacking up the engine.
In short, the 5.4 is a waste of time. A 4.6 will make tons of power, and be much easier to get in there than the 5.4, if you really want a mod motor.
Old 05-16-2004, 08:07 PM
GTStang's Avatar
Stang Guy
Re: Re: 5.4
Originally Posted by HiFlow5 0
LOL!
Hey I figured I'd get to the point... LoL
Old 05-16-2004, 09:53 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: 5.4
5.4 too much work, I'll stick with the 4.6 or 5.0 both have good bang for the buck.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 05-17-2004, 10:12 AM
block strength
Which block (the 5.0 or the 4.6) can handle more horsepower?
What are the Pros and Cons of each block?
Thank you all!!!
Old 05-17-2004, 04:12 PM
Re: block strength
Thank you all!!!
A stock 5.0 is spilitting at around 500 RWHP. A stock 4.6 block with a cobra crank, some good aftermarket rods and pistons will handle 1000++ horsepower. Only cons of the 4.6 are a bit less power because of less inches.
Old 05-17-2004, 04:53 PM
driftstar2 driftstar2 is offline
Send a message via AIM to driftstar2
Re: 5.4
I was considering putting a 5.4 in my 97 4.6 standard stang, aren't they more horsepower and torque stock? wont they bolt and plug in? whats the info on swapping it in my car..
Old 05-17-2004, 06:50 PM
Thank you boosted331
Im suprised at how many people actually replyed to this thread, thanks to all!
Old 05-19-2004, 10:08 AM
Mercracer Mercracer is offline
Re: Re: block strength
You left out the disproportionate amount of money it takes to build that 1000HP 4.6 and bolt it into a car with an ignition/fuel system to support it, versus a 302/351W based build.
You can buy a Sportsman block and fill it with a stroker rotating assy. for less than it will take to put your 4.6 motor together, and make it work.
QUOTE=driftstar2]I was considering putting a 5.4 in my 97 4.6 standard stang, aren't they more horsepower and torque stock? wont they bolt and plug in? QUOTE]
Putting a 5.4 into a 4.6 car or a 5.0 car takes even more time, money and effort than does putting a 4.6 engine into a 5.0 car. If you just want to go fast/quick and you do not have a huge budget, don't bother. Keep it simple. I have seen cars in the 10's with blowers on a factory 5.0 shortblock, and I am running low 11's on a factory Explorer shortblock with N2O. Cams have been changed on both shortblocks, but no internal engine work was done.
Old 05-19-2004, 05:02 PM
Re: Re: Re: block strength
Are you kidding me? A sportsman 302 block is BARELY stronger than a late model thin wall casting, and is basically identical to an early model high nickel block. With a 4.6 you need some 600 dollar rods and 600 dollar pistons, and your bottom end is solid to 1000+ horsepower. To have a 302 motor that will take 1000+ horsepower you need 1500+ for a block, 800 for a crank, 600 for some rods, 600 for some pistons. For the 4.6 swap all you need is a new ECU, swap k-member, and some ingenuity. The cost of the swap is easily taken care of just by the price of buying a good block (Dart, R302, World) not even including machine work. Keep in mind a bare R302 needs quite a bit more machine work than a preused 4.6 block to get it ready to run.
Old 05-20-2004, 01:31 AM
HONDABOND HONDABOND is offline
Re: 5.4
http://www.fordracingparts.com/parts...tKeyField=6531
VS
http://www.fordracingparts.com/parts...tKeyField=6374
I am scratching my head and wondering to myself 1. Were are you going to find a "Used" 4.6L 32 valve motor. 2. why would you pay out the ass for one when you can get a new performance "5.0" that drops right in with no hasle and has the same horsepower and torque and costs half as much... Makes no sense to me.
Althoe the new technology IS badass and I have been waiting for american companies to start using OHC technology for quite some time, I stilldont think its worth twice the amount as a high performance engine that puts out equal power.
White folk eat noodles too.
