Old 05-14-2004, 11:57 PM
SikNingStang SikNingStang is offline
Send a message via AIM to SikNingStang
351 question
whichever 351 is based on the 400 block be it the windsor or cleveland I was having a discussion how do they make a 400 into a 351? Destroking or what? I can't figure it out how they make a 400 into a smaller 351. Can anyone explain? Thanks
Old 05-15-2004, 01:17 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I thought the 400 was based off the 351M. Cause, for intance, back in the late 70's there was a 351M/400 option for the F-series trucks. I do believe the difference is the stroke too, but I could be wrong.
Speaking of 400, woohoo 400 posts. Yeehaa!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-15-2004, 02:46 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 351 question
Yep, the 351M, almost a boat anchor.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 05-15-2004, 03:01 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The 400 came first and was designed for trucks and large passenger cars. It is based of the Cleveland block with some differences like main journal size and it's bellhousing pattern for big-blovk transmissions. Then due to the gas crunch and clean air acts Ford de-stroked the 400 to 351cu hence the name 351M M=modified.
These motors are great for what the intended purposes esp. trucks. But as far as for Mustangs and performance applications boat anchors would be the correct term. LoL
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-15-2004, 07:17 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 351 question
The 351M was designed to replace the 351C. Ford only used the “M” designation to distinguish it from the 351 W (Windsor) and the 351C (Cleveland). The “M” designation has now become know to mean “modified” or “Michigan,” even though the 351M was produced at both the Cleveland foundry and Michigan casting center, and originally had no meaning but as an identifying mark.
The 351M is pretty close in comparison to the 351C. The stroke is still 3.5, but the main journal diameter enlarged from 2.75 inches to 3.0 inches to allow for a greater bearing wear area. The 351M is also close in comparison to the 400 (destroked 400=351M), and all have one big thing in common. The valve trains are all interchangeable (except pushrods) and the cylinder heads are all compatible. The 351M is designed to make more low end torque for bigger cars and trucks, and was built with emissions regulations in mind that the 351C couldn't handle. Lastly the 351M was mass produced from 1974 till 1979, but still popped up in some Broncos, F250 and F350's till 1982.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-15-2004, 01:08 PM
HiFlow you sound like an encylopedia.
Old 05-15-2004, 06:07 PM
Re: 351 question
so by "de-stroking" do ya mean that they put a smaller crank and longer rods or just a smaller crank?
Old 05-15-2004, 08:17 PM
Rod length has nothing to do with stroke, because if a longer rod travels (for instance) .5" higher to TDC, then I will be .5" higher than BDC as well. It is the crank that increases stroke that is correct. So a 351M is a 400 with a shorter crank stroke.
Old 05-16-2004, 02:19 AM
motor_head_429 motor_head_429 is offline
I'm not completely sure of it, but I believe the 351 had a 3.50 stroke, while the 400 had a 4 inch stroke, both had 4 inch bores. Here's something that might help. http://www.fordcobraengines.com/Modified%20History.htm
