Old 05-14-2004, 08:47 PM
Soupnutz Soupnutz is offline
what next
I'm in the process of buying a 1998 mustang gt and with the mods the previous owner has done I'm not sure where to go next. Heres what's been done so far.
steeda underdrive pulleys, timing adjuster, msd 9mm plug wires, ngk plugs, k&n filter, king cobra clutch, adj. clutch quadrant, firewall adjuster, adj. clutch cable, bassani x-pipes and quiet thunder exhaust, aluminum drive shaft, 3:73 gears, tokiko 5 way adj shocks, h&r super short springs, heavy duty end links, caster/camber plates, strut tower brace, steeda heavy duty sway bar (front and rear), aluminum rack bushings, steeda upper/lower control arms, and all suspension bushing have been replaced with polyurethane ones.
The only thing not really touched is the engine and the only thing I can think to start with would be be some headers and maybe a pi head swap when I get the money. I also have a suspension question, with the work that's already been done to it and it being a coupe should I get sub-frame connectors or would that be a waste of money?
Old 05-14-2004, 08:55 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Subframes are never a waste. It sounds like a pretty nice start already.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-15-2004, 03:16 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
To spend all the money and not have subframe connectors is a waste of money. Sub-frame connectors OWNZ ALL!!!!!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-15-2004, 09:00 AM
Re: what next
What should I expect to pay to get some of those welded on?
Old 05-15-2004, 01:23 PM
You can pick up a set of nice subframes for like $100. Take it to an exhuast shop and talk to the guy, they'll usually take in any minor welding job. I'd say maybe 2 hrs and $100 - $150 labor
Old 05-16-2004, 05:33 AM
GTStang's Avatar
Stang Guy
Average you should pay about $100 to have em welded on.
Old 05-17-2004, 05:24 PM
Re: what next
That's not too bad, a guy I work with has a welding generator at home, think I might stick with a pro though.
Old 05-17-2004, 05:41 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: what next
Any body shop should be able to do it the difference is the price.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
