Old 05-12-2004, 10:05 PM
bigbob bigbob is offline
the tentative plan
ok fellas after gaining some knowledge i think i have a game plan for my 95 vert auto gt (45k miles}
{air silencor removed/ingnition timeing=14}
catless h pipe and muflers not sure the brandprobly mac/ fllows but that is jst based on soud clips.
rear gear"4.10"
under drive pullies
trans go shift kit{or an all new valve body}
a posible 100 shot of nitrous
and ever guy knows who important rubbers are so ill get some sticky ass tires.
what do u fellas think i should change or +/- from this. and ideas of hp/ 1/4 mile time thanks
Old 05-12-2004, 11:04 PM
BlueovalWhig's Avatar
BlueovalWhig BlueovalWhig is offline
Thumbs up
You could change to a bigger throtle body(70mm), cold air, bigger mass air(75mm), calibrate it with larger fuel injectors(24 lb) a better fuel pump 255lph get that air flowing in you already have it flowing out with these plans
Old 05-13-2004, 10:17 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: the tentative plan
Actually, I wouldn't do any of those at the moment on his car. Running a 70mm TB will lose torque on the low end, and that auto is going to need all it can get on the low end. If anything a 65mm would be best at this point.
Bigger injectors are definitely not needed either, the 19 lbs-hr will suit just fine with what he's running.
bigbob, one thing you might want to consider is subframe connectors, they are all most a must on verts. I say do what you have planned right now, see how everything works, and it will give you a little time to get use to the way the car will now handle. Then, start on the breathing of the car, TB, MAF meter, intake etc.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-13-2004, 02:39 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Sounds like a pretty solid plan to me and sub-frame connectors are never a bad idea. Especially in verts or t-top cars!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
