Old 05-06-2004, 03:51 PM
bigbob bigbob is offline
juice
hey fellas what is a safe shot of nitrous for my 95 gt to handle. its stock right now. but plan for upgrades later
Old 05-06-2004, 04:25 PM
Zwrangler's Avatar
Zwrangler Zwrangler is offline
well if you're planning on extra upgrades later then it would be wiser to wait until you get your engine stronger and faster so that it can handle a bigger shot of Nitrous instead of buying a small system now and then in future having to buy another bigger nitrous system for your engine. I'm sure a stock v8 could handle anywhere between a 50-100shot of nitrous depending on how strong the engine is and how its holding up.
This is a really tricky thing as if you get a shot too big for your engine to handle it could blow your engine and cause you much pain in future
thats why i suggested maybe waiting until you build up the engine a bit more and then maybe go for the nitrous shot to make sure your engine can take it.
93 camaro Z28 R.I.P.
From this......................to this and this
check it out at my website
"Pain heals, chicks dig scars but glory is forever !"
Old 05-06-2004, 04:27 PM
Re: juice
thanks for the imput
Old 05-06-2004, 06:32 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
General rule of thumb V8 can take 125-150 shot stock when in good shape.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 05-06-2004, 08:03 PM
eillob's Avatar
eillob eillob is offline
Re: juice
I agree completely.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 05-06-2004, 08:14 PM
tds715 tds715 is offline
Send a message via AIM to tds715
Re: juice
i was told with a 75 shot of dry i may hurt my 5.0 is that true.
94 accord in works h23 turbo full body kit and bit of shaving and new paint
88 gt 5.0 just gettin started
Old 05-06-2004, 08:33 PM
GTStang's Avatar
Stang Guy
Not unless it is set-up wrong... a good condition 5.0 can take a 75HP shot no prob.
Old 05-06-2004, 08:52 PM
Re: juice
75 dry tho? i was toled it wont compinsate the fuel though.
Old 05-06-2004, 09:51 PM
eillob's Avatar
Anytime nitrous is introduced to the combustion chamber extra fuel needs to be added in order to make and add power safely.
A dry nitous kit will add more fuel by way of your injectors. I'll use a Zex Nitrous kit for example mainly because thats what I use.
This kit comes with a NMU. Which is basically a brain that box that houses your solinoids. When you arm this kit and are at full throttle the brain box adds nitrous and at the same time increases the amount of fuel at your injectors, thus producing more power. I can't speak for all kits because I haven't used them all but thats basically how it works with a dry kit.
Nitrous is like any mod You make. It works best when other mods have been done. I would suggest doing all your basic bolt ons first then do nitrous because you'll get more out of it.
Old 05-08-2004, 03:06 AM
motor_head_429 motor_head_429 is offline
Re: juice
Might sound stupid, but I wouldn't run the 150 or even the 125 shot with the AODE tranny that came in 95. The T5 though I think would be just fine with that.
Old 05-08-2004, 06:22 AM
Re: juice
man i really wanna juice this car. but most of my friends, are telling me that its gonna screw this motor up.
i had a kit on my honda before and never had problems.
Old 05-08-2004, 09:24 PM
eillob's Avatar
There are basic rules to learn when using nitrous. Some people ignored those rules and nitrous kinda gotta bad name. Its like anytime you mention nitrous thats the first thing people think. There goes your engine, but thats not true.
Nitrous when used correctly will not harm your engine. The problem is people use it and then don't know where to stop. Your fuel to nitrous combination is key. Most kits will show you how to do that but you know, theres that question. " I wonder what would happen if I added a little more?" You get more nitrous then fuel you'll have a problem.
The fastest nitrous cars are the ones that haul ass when on no juice. Nitrous is at its best when used as an enhancement not a necessity.
Old 05-09-2004, 01:07 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: juice
I agree 100%
Stupid people with nitrous harm engines.
Old 05-09-2004, 01:07 PM
boosted331 boosted331 is offline
Re: juice
I ran a 250 shot through an NX plate on a stock HYPEREUTECTIC shortblock with TFS heads/cam/intake. Ran a seperate fuel cell with C16 for the nitrous kit, with a WOT switch, FPSS, and RPM switch. As long as you play it safe it'll work out fine.
