| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Today I got my 78' corvette (pace)
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting For painting the body I bought black spray and silver color. I think I will first paint the silver, then cover it (seal the edge with maskol) and spray the black. the problem is that I'm affraid the maskol won't be staright and so the black won't be too. (thought i'm not sure it matters cause a decal will cover it later). Anyway, does anyone have a better way to paint the body? Thank you! |
Re: Hot to paint 2 color body
Use low tack tape to mask the line fi you want it to be straight
Use Tamiya thin masking tape or 3M's pinstriping tape.
hth, Bill |
Re: How to paint 2 color body
I think you should always paint metallic colours (silver, in your case) last. Paint black first followed by the silver.
Thanks.
I don't have Tamya mask tape, but I'll use something instead. I will paint black before silver. may there be a problem using maskol on paint that was sprayed? |
i have the same question. will blue painters tape work. i have used it on my lawnmower project and it is low stick and will peel up withing it a week or so without becoming all stuck. but will paint seep thru?
Silver then black...
general rule of thumb is paint lighter colors first. I've had good success with blue painters tape as well as fine line tape. If you are worried about the paint bleeding under the tape just apply a light coat of clear on the tape before you spray the second color. See the PT panel linked in my signature for an example.
SCCA 7, The lost Z Contest entry thread: Mystery? Beetle + Boxster = Bugster, P.T. Panel:click here Diablo Roadster: click here, & Porsche C2 Cab |
It has a two color scheme using what I've told you. And I also painted the blue after the black to get this deep blue, over white... it would su.. at least for I was looking for
I'm not sure you understood what I ment.
I don't mean to paint one color OVER another. I'm going to paint both on the uncolored body. I'll cover the siver (I color it first), so the black spray won't get to the lower part of the body- where the silver suppose to be. |
I understood you, but to paint a two color scheme you must paint one over another, you must paint first the less opaque one, like you want black and silver, paint it black, and after this mask what you dont want to paint and paint silver, yes, silver over black. I know that you are thinking that black is the darkest one and should be painted after silver and the silver over the body color or the primer, with any other color is the way to go, but no with silver.
Ok, but why must I color one on the other? Can't I cover the lower part on the body, spray the black on the upper part and then paint silver on the original white?
^^ well you can do that.. but then you will need to mask the thing 2 times...
Why 2 times? only once- when I spray the black.
btw, I don't think its possible to paint any color on a sprayed color, is it? |
here is my way i would o about doing your 2 tone.
sand the body primer wet sand primer shoot the car all black. mask off the top half. lightly wet sand the black that you will paint over with silver shoot silver pull the tape take a good 2000 grit and wet sand the line were you masked 2 tone is easy, it is when you get into multipul colors. right now i am in a dilema, on finsihing my f-150 4 tone truk. |
