Old 05-01-2004, 10:49 AM
nismo kid nismo kid is offline
strip paint
i need help on how to strip acrylic paint, ive tried the brake fluid but it didnt do anything, the paint is 'Halfords automotive paint' ,
Rich.
Old 05-01-2004, 11:25 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: strip paint
Castrol Super Clean. Unless the paint "etched" into the plastic, There's really no way to remove it then, Have to sand it all out.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-01-2004, 11:32 AM
freakray freakray is offline
AF Modelrater
Re: strip paint
Halford's automotive paint isn't acrylic, it's acrylic lacquer
How long did you leave the paint in the brake fluid, the stripping isn't instantaneous, you may need to leave it in overnight or even several days.
Of course, as Josh mentioned, if it etched the plastic(which will happen if you didn't primer), you have a whole different problem.
AF User Guidelines
Old 05-01-2004, 11:35 AM
Toughbeard's Avatar
Toughbeard Toughbeard is offline
Send a message via ICQ to Toughbeard Send a message via MSN to Toughbeard
Re: strip paint
You can try the marveleous invention called "Stinca". İt removes every paint we tried, it is water based and non toxic removes even the most stubborn paints. Check www.modelciler.org
Toughbeard...
Destroyed Projects: 1/20 Tamiya BMW/Williams FW-24
Noob Projects:1/24 Tamiya GT3 + Tamiya 1/12 Honda NR
Old 05-01-2004, 12:09 PM
Renegade's Avatar
Renegade Renegade is offline
Send a message via MSN to Renegade
Re: strip paint
Right at this moment I'm striping the paint with DOT3 brake fluid. For now there's no visible progress but the paint is getting sticky.
Keep your fingers crossed.
Old 05-01-2004, 01:48 PM
Howielong's Avatar
Howielong Howielong is offline
Send a message via AIM to Howielong Send a message via MSN to Howielong Send a message via Yahoo to Howielong
Re: Re: strip paint
Is there an english site.
Old 05-02-2004, 02:43 AM
Toughbeard's Avatar
Re: strip paint
un fortunately no howielong ted: but if you write to the forums in english you will get response, plus you write to the admin directly. English perfectly spoken here tell them "Toughbeard" Sent you i:
Toughbeard...
Old 05-02-2004, 08:37 AM
Renegade's Avatar
If may I jump in ... the brake fluid striped the paint completly . Than I soaked the model into water which had been added degreasing washing detergent. I let it bath for about 2 hours than changed water with a fresh one and repeated the process.
Today I took the body out and wash it under running water and put it in container to dry. Right now I was looking at the body and I think the plastic is melting. Panel lines are melting together and plastic is kinda soft. If you press hard with a toothpick it leaves a mark - tiny hole. Similar is happening with 'rubbers' on bumpers and molded emblems.
Automotive plastic primer (I used DupliColor clear one) and paint also attacked the roof of the car - roof panel lines are off
Now I'm soaking the body in water with added very little of washing detergent, but I think I can still see some brake fluid in door molds.
How can I wash off all the brake fluid? Is this brake fluid attacking the plastic or washing detergent? I'm also thinking about rubbing the body with salt, which 'drinks' (don't know the word) the water out?
Although the model is permanently damaged ...
Old 05-02-2004, 10:15 AM
Toughbeard's Avatar
Re: strip paint
yes brake fluid will remove paint too (must be dot 3) but it will attack putty and cement as well. so use carefully.
Toughbeard...
