Go Back   Automotive Forums Car Chat > Datsun > General Discussion
Old 05-07-2001, 08:24 PM
3drival 3drival is offline
Send a message via AIM to 3drival
Hello,
I have a 1973 datson pickup and I was wondering if the points would cause it to back fire? If so What should I do?
Daniel
Old 12-07-2001, 03:57 PM
BleachZee BleachZee is offline
Send a message via Yahoo to BleachZee
Backfire?
No, the points won't cause it to backfire.
If your timing is way off, it might cause it to backfire. Are you talking about firing out the exhaust, or firing up out the carb?
If you are firing out the exahust, then maybe your points are too weak to ignite all the fuel or the carb is going bad and doesn't give a good mist of the fuel. Also, your timing chain could be slacked and the valves could be slightly off. If your valves are not adjusted properly, and they don't seal well then you could backfire out either the exhaust or intake.
Of course you wrote that post so long ago that you probably sold the truck by now!
You can bolt a distributor from a 1977-79 Datsun truck that uses electronic ignition. Just plug the two wires from the side of the distributor onto the + and - of your coil. of course, the positive on the distributor goes to + and negative to -. Use a manual to figure out which is which if the wires are not red and black.
distributing Skylines in USA cisco35 General Discussion 61 10-12-2004 03:12 PM
bad distributer? Quetzolcotl Integra 0 05-10-2002 01:24 AM
Weight distribution Edho2002 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 04-23-2002 09:51 PM
Linux Users.. Help me choose a distribution. Rich COMPLETELY off-topic 4 03-13-2002 10:21 AM
