Go Back   Automotive Forums Car Chat > Hyundai > Tucson
Old 04-28-2004, 05:43 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
First look at the Tucson
The Central Region Parts Distributer Manager was just at my dealership today and was driving the new Hyundai Tucson. There are only 2 of them in the United States, both as test vehicles. They will not start producing them for another 2 months, and will hit showrooms in September. They are being driven so they can work out some bugs that might occur. Very similar to the Sante Fe, but smaller. Has a lot of small features that you normally wouldn't look at, but they are nice. Like, a tailgate glass that opens separate from the tailgate, power outlets in the cargo area in the rear, etc. Also, for front seat passengers, a lot more head and leg room than the Sante Fe. For being a small vehicle, it seems a lot bigger than the Sante Fe on the inside. Should be a nice buy for anybody wanting a small SUV, but can't afford a Sante Fe. Also, JD Power released statement today that Hyundai now surpases Toyota in initial quality. A big step for Hyundai now ranked 7th among all manufacturers in initial quality.
John Nance, Parts Manager
Bob Rohrman's Indy Hyundai, Suzuki Superstore
7101 East Washington Street
Indianapolis, IN 46219
www.indyhyundai.com www.indysuperstore.com
1-866-290-7046
317-613-7048
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 04-28-2004, 06:23 PM
Tiburon99 Tiburon99 is offline
Re: First look at the Tucson
Cant wait for it to come out. heard about Hyundai's uprise against Toyota....ALL POWER TO HYUNDAI!!!!
Old 04-28-2004, 07:30 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
any change in performance... any number difference between the tuscon and sante fe?
Old 04-29-2004, 08:21 AM
Authorized Vendor
Re: Re: First look at the Tucson
The Tucson will only be offered with the 2.4L and 2.7L. No 3.5L in it. The guys that were here with it said acceleration was pretty good with the 2.7L. I hope the 2.4L isn't as bad as it is in the Sante Fe. I am driving a 4cyl Sante Fe as a demo right now, and it's a dog. Takes forever to get up to speed getting onto the interstate, unless you leave it in 2nd or 3rd.
John Nance
Parts Manager
Terry Lee Hyundai
Old 04-30-2004, 10:58 AM
C-DUBYA C-DUBYA is offline
2005 HYUNDAI TUCSON TECHNICAL SPECIFICATIONS
Download in Word format
ENGINE
Type: Hyundai Beta 2.0-liter DOHC 4-cylinder, inline with CVVT (transverse mounted)
Materials: Cast iron block/aluminum cylinder head
Displacement: 2.0 liters (1975cc/120.5 cubic inches)
Bore x stroke: 82.0mm x 93.5mm (3.23 inches x 3.68 inches)
Compression ratio: 10.1:1
Horsepower: (estimated) 140 @ 6,000 RPM
Torque: (estimated) 136 lb-ft @ 4,500 RPM
Valves per cylinder: Four
Fuel system: Electronic multi-port fuel injection, in-tank fuel pump
Emission controls: Three-way catalyst
Exhaust: Single
Type: Hyundai Delta DOHC V6 (transverse mounted)
Materials: aluminum block/aluminum heads
Displacement: 2.7 liters (2656cc/162 cubic inches)
Bore x stroke: 86.7mm x 75.0mm (3.41 inches x 2.95 inches)
Compression ratio: 10.0:1
Horsepower: (estimated) 173 @ 6,000 RPM
Torque: (estimated) 178 lb-ft. @ 4,000 RPM
Exhaust: Dual
TRANSMISSIONS
5-speed manual
1st 3.636:1
2nd 2.056:1
3rd 1.333:1
4th 1.061:1
5th 0.821:1
Reverse 3.455:1
4-speed Shiftronic automatic
1st 2.842:1
2nd 1.529:1
3rd 1.000:1
4th 0.712:1
Reverse 2.480:1
Final drive ratio
GL, manual trans 4.533:1
GL, auto trans 4.626:1
GLS & LX auto trans 4.407:1
SUSPENSION
Front: Independent: MacPherson struts with coil springs, hydraulic shock absorbers and 21mm anti-roll bar
Rear: Independent: strut with multi-links, coil springs, hydraulic shock absorbers and 14mm anti-roll bar
STEERING
Type: Power-assisted rack and pinion
Overall ratio: 16.2:1
Turns, lock to lock: 3.1
Turning circle: 35.6 feet (curb to curb)
BRAKES
Front: Power-assisted 11.0-inch (280mm) vented disc with floating two-piston calipers and pad wear sensor
Rear: Power-assisted 10.3-inch (262mm) solid disc (FWD) 11.2-in (284mm) solid disc (4WD)
ABS: Optional, four-wheel, four channel
WHEELS 5-spoke, 16 x 6.5 alloy (4-cyl)
6-spoke, 16 x 6.5 alloy (V6)
TIRES P215/65R-16 (GL)
P235/60R-16 BF Goodrich Traction T/A (GLS & LX)
Compact spare tire, T155/90R16
EXTERIOR DIMENSIONS
Wheelbase: 103.5 inches (2630mm)
Overall length: 170.3 inches (4325mm)
Overall width: 70.7 inches (1795mm) 72.1(1830mm) with cladding
Overall height: 66.1 inches (1680mm) 68.1inches (1730mm) with roof rack
Tread width, f/r: 60.6/60.6 inches (1540mm/1540mm) GL
61.0/61.0 inches (1550mm/1550mm) GLS & LX
EPA passenger volume: 102.6 cubic feet
EPA cargo volume: rear seat up: 11.5 cubic feet;
rear seat down: 28.4 cubic feet;
total: 39.9 cubic feet
EPA total volume: 110.5 cubic feet
CAPACITIES
Fuel tank: 15.3 gallons (58 liters) L4
17.2 gallons (65 liters) V6
Engine oil: 4.2 quarts (4 liters) L4, 4.8 quarts (4.5 liters) V6
Engine coolant: 3.1 quarts (2.95 liters) L4, 4.8 quarts 4.5 liters) V6
CURB WEIGHT
L4, FWD, manual trans: 3240 lbs.
L4, FWD, auto trans: 3265 lbs.
L4, 4WD, manual trans: 3425 lbs.
V6, FWD, auto trans: 3370 lbs.
V6, 4WD, auto trans: 3548 lbs.
www.toontoys.ca
THE WAY YOUR GIRLFRIEND LIKES IT...BIG AND DIRTY!!
Old 09-21-2004, 09:00 AM
Kat03Tib's Avatar
Kat03Tib Kat03Tib is offline
Hyundai NorCal Meets Vendor
Send a message via AIM to Kat03Tib
Here is a pic of the Tuscon from our Norcal meet.
And a pic of a prototype Elantra soon to be sadly crushed!
________
cheap volcano vaporizer
Old 11-04-2004, 12:09 PM
slim84maro slim84maro is offline
Send a message via AIM to slim84maro
what is a tuscon? that suv thing? i thought this was a misprint when i first seen it. thought it was sapposed to be tusconi
check out www.v8havoc.com
Old 11-06-2004, 10:53 PM
tiburocks tiburocks is offline
its tucson
Old 11-07-2004, 06:49 PM
whats the difference between a tuscon, and a tusconi?
Old 11-07-2004, 07:59 PM
just the name... i guess
