Old 04-27-2004, 04:01 PM
2crunk's Avatar
2crunk 2crunk is offline
2003 GT: Bolted Battery?
I'm trying to replace the headlights with aftermarket ones and to get to the driver side bulb, i need to move the battery. I disconnected it and tried to pick it up and it wouldn't budge. I was wondering, is the battery bolted down? If so, where is it bolted down at and how can i get to them?
Old 04-27-2004, 04:17 PM
rerun rerun is offline
did you take off the hold down?
Old 04-27-2004, 10:06 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
There should be a little plastic wedge down the side of the battery that screws into the fender through the battery box. It should be an 8mm.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-28-2004, 10:12 PM
Retread's Avatar
Retread Retread is offline
Re: 2003 GT: Bolted Battery?
Ya know, in the manual sez to remove the 2 pins on the top of the headlight, they're just behind the front brace. They look like a tent-peg sorta, with a bent over tab at the top. Pull straight up and slide the whole assembly out the front... you don't have to rem the battery.
Word of caution, fire some water under the bottom edge of the light assembly or put a rag over your bumper, there's a lot of road grit that gets under there and could scratch the bumper.
Old 05-29-2004, 01:35 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: 2003 GT: Bolted Battery?
Yea man those headlights are a snap there are 2 slides that lock em in place for each assembly. Nice and easy unlike the god dam fucking Fox headlights!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
