Old 04-27-2004, 11:28 AM
2crunk's Avatar
2crunk 2crunk is offline
Air Silencer?
I was told today that my mustang had an air silencer. He said that if i removed it, i could gain up to 10Hp. I was wondering, if it were to be removed would any "check engine" lights come on or is there anything negative about doing this? I also wanted to know if it does not cause any damage to my motor, how can i take this out? Thanx for the help.
Old 04-27-2004, 11:58 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Air silencer in located in the stock air filter box going out into the fender. Take but a minute to get out.... I'm sure it helps flow but 10HP is very optomistic.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-27-2004, 12:06 PM
2crunk's Avatar
Re: Air Silencer?
Does the air silencer just pull out or does it need to be cut out, also i heard that i can't pull it out the way it is, i mean, it has to be taken out thru the fender well. If so, how can i do this?
Old 04-27-2004, 12:40 PM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
nO, NO LIGHTS WILL COME ON.....
Just yank it out and put a K&N Filter charger kit on it (from www.Summitracing.com)......if you order the kit (56$+) it will have instructions with it how to do it.
It is cosmetic at best and will get you a max of 5 hpmabey 3-4hp but Better air flow means better performance and better engine life.
I got 10-12 hp because I put the K&N filter on the end of my "boot and did not put it in the fender, just let it hang in front of the passenger side of in front of the engine but near the ground to get max air..
Your basically taking some "strain" out of your intake area by allowing more air in.
TK
Old 04-27-2004, 12:51 PM
2crunk's Avatar
Re: Air Silencer?
what does the air silencer look like on a 2003 mustang gt?
Old 04-27-2004, 01:18 PM
Rodek Rodek is offline
Re: Air Silencer?
this isn't for a 2003, but it will still give you the basic idea:
http://www.mustangworld.com/ourpics/fcar/intke.htm
1994 Mustang GT Convertible
Bone Stock (for now)
http://www.cardomain.com/memberpage/518962
Old 04-27-2004, 01:33 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Air Silencer?
Air silencers are junk, and a waste of money that Ford decided to put into the cars because some people thought it was the noise the air made was annoying as the motor was rev'ed.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-27-2004, 02:57 PM
2crunk's Avatar
Re: Air Silencer?
thanx for the help, took it out with the help of the website RODEK gave me. http://www.mustangworld.com/ourpics/fcar/intke.htm
Old 04-27-2004, 03:22 PM
Re: Air Silencer?
booyah, cept i am a hypocrit cuase i havn't even taken mine out yet...the reason i am concerned is that it leaves that huge hole open to underhood airs which is pretty hot while even if the air silencer is restrictive, it still does take it cold air from the fenderwell
Old 04-27-2004, 06:17 PM
Joshta's Avatar
Joshta Joshta is offline
The removal would get a few at max, I personally didn't notice a difference, but then again i have a 99 v6 auto. some car mag took a bullet mustang and did some light mods, but said they didn't notice a difference when they took the silencer off. Myth or Miracle, you decide.
