Old 04-27-2004, 01:33 AM
Blitz_Runner's Avatar
Blitz_Runner Blitz_Runner is offline
BAD noise when turning. need help!
I drive a 93 civic LX and i bought it about 7 months ago. The prob is that its got a clacking or knocking noise when i turn left or right. It does it when cornering tight at speeds about 30 - 45 mhp, and it also does it when accelerating and turning. never when just accelerating. I'm guessing its got something to do with the breaks (which are old) or the bearings. So if someone could help me out that would be great! Thanx!
Old 04-27-2004, 01:49 AM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Re: BAD noise when turning. need help!
check your CV boots.
Old 04-27-2004, 02:10 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You don't need 2 threads in the same forum right under each other, 1 thread is fine man.
http://www.automotiveforums.com/vbul...d.php?t=219290
As I said in the other thread, it's probably your CV Joints, so check those. Bad CV Joints tend to make a clicking sound, especially when turning. If you had/have a leaky CV Boot, then something got in though the leak and messed up the CV joint, which is why it clicks. If you catch a leaky CV boot asap, it is possible to replace just the boot if your CV joint isn't damaged. If you let it go, the CV Joint will get damaged...You'll probalbly need to replace the half-shafts then. It was probably let go, and it messed up your CV Joints.
Old 04-27-2004, 08:13 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
I had the same "clacking" noise in slower turns and it turned out to be a busted motor mount on the driver's side. More than likely it's the CV joints though. Blitz, check behind each of your wheels and see if everything's covered in grease. It's like a silver color and it will be all over the place. If there is none, check around the rubber boots for cracks and grease.
If those are fine, check your motor mounts to see if they're loose or something. If those are fine, check your springs/suspension to see if they're on straight. If not, sometimes the springs (under pressure from turning like you said) will squeeze and kinda grind.
Old 04-27-2004, 01:07 PM
Aight, thx guys. i looked behind me wheels and around that area and didnt find anything and there is no leaking on the ground or anywhere else. i got a bro in a car garage that said he can hook me up with a little check-up on that.
Old 04-27-2004, 09:06 PM
95civsi 95civsi is offline
i bet its one of the CV joints. i had the same problem about a month ago. it got so bad that when i was goin down the road at about 60, the car jerked to the right and almost ran me off the road. then i got to my house and i backed into my driveway and i heard this loud popping noise and i couldnt move the car. it cost roughly $190 for the shop in town to fix it. which really sucked ass
